Question about RCA D52W19 52" Rear Projection Television
Power up, attempts to turn on, then shuts off, tries again, off, 1 more time, finally shuts off. can't do anything for a few minutes, then does the same cycling next time try to turn on again. only visible lite is the green led power button itself, no pix/sound, tho that usually takes a while to come up normally. fine last nite, other tv/dish working, good outlet/pwr. etc. tried to unplug for while, same results. see no reset button. fixable?
  • RCA Master
  • 8,617 Answers
Replace the three deflection capacitors CP150, CP120 and CP114. You can get the repair kit by that same name from www.tvrepairworld.com which also contains the CD with instructions.
Posted on Aug 21, 2010
  • Penelope Pope Nov 24, 2012
    Did replacing the deflection capacitors work? I have the same problem.
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
My LG surround sound, model lg dvt418 or possibly lgdvt418, will not power on for some reason. It started off where i would have to press the power button quite a few times for it to power on and the last...
100 times? If it wasn't worn out it surely is closer to becoming so.
If you have the remote, try THAT to see if it makes a difference. I have an old receiver with a flaky power switch an I just use the remote to power it on or off when it gets persnickety.
If it responds momentarily to power activation and turns off maybe it senses a dangerous condition and wants to shut down. Try disconnecting the speakers first and see if that changes anything.
Jul 19, 2011 | Audio Players & Recorders
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
My Sony flat screen when first turned on will run just fine for about 30 minutes. Then it will start turning off and on about a dozen times, be ok for about 20 minutes and do it again. I finally just turn...
You might be able to see what is shutting the set off. Sony models employ a memory for failures. When the set is off push: Display, 5, Volume down, Power. Make sure your push all within 1 second. The set should come on with a display of the errors. A list of items followed by 0 ro 1. anything with a 1 has shut the set off. With that info at least you will know going to a Sony repair center what you can expect to pay or at least have a better idea.
Mar 25, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Whirlpool duet sport washer powering off during spin cycle
I had this problem with new duet sport washing machine. Service was out to fix under warranty (4 trips!) replacing water sensor and boards. Finally checked outlet and was told no neutral. ?? Charged us for that visit since not covered. Plugged into another outlet and it worked. Had electrician in, replaced original outlet (although saw no sign of bad connection) and washer worked again! Yippee until today when I had the same issues. Tried in another 2 outlets and still shut down after a few minutes (and in those few minutes it never really ran as it should) Went out to get an outlet sensor ($8 at hardware store). Plugged in and found no errors. Started washer again and it did run and completed cycle. Although estimate 1 minute of final spin cycle took almost 25 minutes (on QUICK wash no less!) Will have to monitor. See if we get lights on outlet sensor next time washer doesn'twork, see what other things in house are running, etc. (although washer on dedicated line). ONLY change since this happenned: We replaced our 30 y.o. electrical box. You'd think this would be better???
Nov 30, 2008 | Washing Machines
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
RCA D52W20 tv will not turn on
mine does the same thing obviously it is a high voltage problem with the power supply or flyback transformer,we have power outages all the time more thank likely it was the colprate good luck ,my suggestion do what im doing throw it in the trash and buy a new one ,it will cost more to repair we live in a throw away society they dont make anything worth the crap any more ,tvs used to last 25 years now if your lucky 5.
Aug 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
1,464 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
