Question about Quasar SP-3235 32" TV
I cannot get chk 0eac2 4840 0000 off of tv....I don't have remote or guide...thank you,,,,Sean
    President:
  • 1,285 Answers
Manual
  • http://dl.owneriq.net/a/ace0fc7a-fac7-4265-9377-c46a5c94afa8.pdf
remote I really suggest a universal (le$$), but here is the original
  • http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12824494394700&smodel=SP3235&brand_pn=QUASAR_SP3235
Posted on Aug 22, 2010
Want to remove key lock for my tv Akira Ct34ds9ae, i don't have orignal remote i have universal remote
I've Akira led tv childs put system lock on when ever i try to make the settings there is 4 digit code comes on screen Can you plz Guide me Master Reset keys
Thank you
Aug 03, 2011 | Televison & Video
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
No spark in a 1987 nissan pulsar 1.8 liter
yes, chk the crank sensor, mounted @front of engine near the crrank pulley. Make sure it is plugged in
May 28, 2009 | 1987 Nissan Pulsar
Expanding picture
Call the service rep who did the work. They replaced the failed parts, but did not find the original cause of the failure. You should tell them that! Replacing the parts without finding the original cause will only cause the present work done to fail again.
Jerry G.
Mar 22, 2008 | Panasonic PT-51G44 51" Rear Projection...
Chk message
i think u r in service mode or factory mode.to exit the set from CHK mode and returns to original factory adjusted shipment mode. press volume(-)button on TV together with TIMER button on the remote control. u will be entered self CHK mode,now turn OFF TV and switch ON, it will be allright.
Mar 08, 2008 | Panasonic PT-56WXF95 56" Rear Projection...
Panasonic Viera TX-37LZD70F - Red 'CHK' message on screen
Your set is in the service mode. TO EXIT THE SERVICE MODE PRESS VOLUME DOWN ON THE SET AND THE OK BUTTON ON THE REMOTE F0R 3 SECONDS.WHEN SELF CHECK SCREEN APPEARS UNPLUG THE UNIT.
Nov 19, 2007 | Televison & Video
Remote not connecting
If you still have the original remote for the DMR-E80H, you can switch it back to operate with "1 CHK REMOTE" codes by holding down the "Enter" button on the remote and then press the "1" key.
If you don't still have the original remote, you can try the same steps on your universal remote (assuming it also has an "enter" key that worked with your recorder) and it could work.
Oct 02, 2007 | Panasonic DMR-E80H DVD Recorder
Quasar SP-3235 32" TV Logo
26 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
