Question about Fujitsu Heating & Cooling
My Fujitsu Converter Air conditioner is not working... The Green light is flashing 13 times - the red light flashes continuously very quickly. The fan does not commence at all and therefore no heat or cool air comes from the conditioner at present. Also, once I press the start button on the remote control unit and the light being to flash, I am then unable to stop the unit - even after pushing the start/stop button - the lights continue to flash. Is there something I can do to make the air conditioner work again, without having to get a technician to service it?? Any assistance would be appreciated. Best Regards, Mary Ann (0412) 750-734
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
technic_7117
  • 38 Answers
SOURCE: THE RED (OPERATION) LIGHT AND
replace the thermistor
Posted on Aug 16, 2010
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
aquaman987
  • 927 Answers
SOURCE: We have a Fujitsu ASY-40UIM3
There are two things that can cause this.
1. Is the high voltage line energized. Is the power coming to the unit, make sure the disconnect is not tripped or manually shut off or pulled out and reversed. Check that the circuit breaker is not tripped.
2. Was some wiring error made with the control wiring that connects the outside condenser to the inside evaporator? Is there power here? Is the transformer working?
I am assuming that the unit was properly filled with gas.
Gary
Posted on Feb 03, 2011
bugoy31
  • 1238 Answers
SOURCE: MY FUJITSU A/C indoor model# ASU36CLX
Good day!!!!
the manual said that error code is cause of discharged thermistor..
-The detection value of the discharge thermistor is either open or shorted > Compressor, outdoor fan: OFF (automatically
releases when the value is returned to normal)
-Check the thermistor resistance values (refer to thermistor value chart)
-controller pcb defective...
Or try to click this link to see the diagnosis:
http://www.e-comfortusa.com/PDF_files/Fujitsu/12RLQ/Fujitsu_12RLQ_Halcyon_System_2008_Troubleshooting_Guide.pdf
Hope it helps..
Thanks for using fixya..
Posted on Aug 12, 2011
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
My fujitsu abt18lbaj won't go, the red light flashes constantly and the green light flashes 4 times
Hi Russell,
I hope the following link is of some help to you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.htmlNIGY5Q
Jan 25, 2015 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
I have a Fujitsu ASU24CL1 and after a loss of power we now have no A/C. Fan works but the red and green lights flash 5 times then go off for a short time then flashes again ?
Seems like a problem with ur condenser power wiring, check diconnect, line from breaker should be in line and line goin to cond should be on load
Jul 01, 2012 | Fujitsu 24C1 Air Conditioner
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps. http://www.oceanairdist.co.uk/assets/pdf/service/Fujitsu/ASYA09LC.pdf
Mat
Jul 04, 2009 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
