Question about HP Pavilion m7100y (PX189AV) PC Desktop
Dvd writer tray won't open - HP Pavilion m7100y (PX189AV) PC Desktop
    Sergeant:
    Champion:
  • 305 Answers
If you look carefully you will see a very small hole on the dvd drive tray insert a small paper clip untill you feel some pressure then press a little harder, tray will open. you might have to move paper clip about a bit till you find the catch.DO NOT DO WHILE POWER ON.
hope this helps
Posted on Aug 21, 2010
I kept a disk in a dvd writer and after sometime it has broken in the writer i have removed the disk tray and removed the broken disk pieces now the tray is not going inside
You need to open the cover of you DVD driver to check if there is some particle left inside the DVD. As there is a possibility that there is something left inside the DVD. If you have idea you can open it and remove everything left inside the DVD.
Apr 26, 2011 | Samsung (SH-S162L/BEBN) DVD RW Burner
Dvd writer & cd writer tray lights up but will not open on HP pavillion model no t760 uk
Go into My Computer and right click your DVD writer/CD Drive and click eject.
Mar 05, 2011 | HP Pavilion a1700n PC Desktop
Dvd writer's flap not going in..
Breaking of cd indicates that the cd is not aligned (tightened) properly between the spindle and the magnetic top, if the tray dos'nt align properly it may not lift the spindle up, open the drive and check for any obstacles in the tray path, important if your drive uses rubber belt to drive the tray in-out replace the belt, also check the magnetic top for breakage.
Jul 24, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
I HAVE A DVD RECORDER VCR COMBO,THE DVD PLAYER NO LONGER WORKS. CAN I REPLACE THE DVD MYSELF OR CAN I GET IT REPAIRED?
You can replace the drive yourself.
This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer. (some with fancy clips you can change from the old unit to the new one)
You simply remove the tray and face plate on the new drive, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap IDE DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Mar 01, 2010 | Televison & Video
My dvd-writer/cd-writer combo will not open?
look a tiny hole in the front of the CD/DVD drive use a paper clip to pull out the tray, when you have the tray out use the EJECT bottom in the drive to close and wait 3 seconds and press again to open, do this at least 3 times.
Fosg2000
Feb 24, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I have a Lite-On DVD writer that will not open unless disk is in.
The problem is with ur DVD Writer Tray, Some of the reason ur dvd writer tray get jammed. For the temporary purpose you can use the manual eject pin hole Technique.
Nov 07, 2009 | Computers & Internet
HP 640b DVD Writer tray will not eject after burning DVD
If all else fails you can take it to best buy
I did that with one of my comp.
Dec 17, 2008 | HP LightScribe dvd640i (DVD640I)...
Door
Hi abdu
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
Hope this helps
Cheers
Deon
Sep 10, 2008 | LG (GCE-8527B) CD-RW Burner
20x Dual Layer LightScribe DVD Writer ±R/±RW/RAM tray opens every time i power my pc up and i have to physically hold it closed
*just disassemble ur dvd writer and there is a light whole in left of the tray in that put any pin or lead and scroll round and try by assembling again ur dvd writer
Jun 19, 2008 | Computers & Internet
HP Pavilion m7100y (PX189AV) PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
