Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron tv kv type
Sony tv
picture blinks have sound.. okay after warm up... for a few minutes.
where exactally is the screen voltage thing and how do you turn it up a notch?
    Genius:
  • Sony Master
  • 1,689 Answers
The screen voltage adjustment should be on the back of the high voltage multiplier. It should be marked as "Screen", or "G2". Next to it, is the "Focus" adjustment.
Some models of Sony sets have two focus adjustments. This is for H and V focus.
When increasing the screen voltage will usually increase the wear factor of the electron-gun assembly in the CRT. This is because it is increasing the screen bias current.
When increasing the screen bias, the brightness will increase a little. When the CRT is weak, this may produce visible retrace lines more so than on a good working CRT. This is because the excessive screen current will stop allowing the electron-gun assembly to work at its proper cut-off level in order to allow the blanking drive to bias it off during the retrace period.
Increasing the screen bias will usually cause a shift in the colour temperature especially in the low level gray colours. This is because the AKG reference for the electron-gun biases will be offset due to the differences in the electron gun performance characteristics change.
Jerry G.
Posted on Jul 12, 2008
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Canno turn the tv on.
You probably have a main or high voltage power supply problem; the latter produces the 20,000 plus volts for the CRT and gets its voltage from the main supply. It's difficult to say which is at fault without a few measurements.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
SONY KV-32FX20U
I suspect you crt tube is going and is most likely not worth fixing
There are things you could do a tv service shop could rejuve your picture tube and adjust your screen voltage.
sometimes that does not work
I would start looking for another tv
thanks doctor video
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron KV35V36 Blinks Every Second
Picture blinks on/off and audio is still there?? If so it's the crt and a common thing for sonys to go out like that.. You can lower the G2 voltage a bit and that might help for awhile or have the tube rejuvenated by a technician - but either idea is only a temporary fix...
Sorry
Bill
Dec 08, 2007 | Sony KV-32FV1 32" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
