Question about Garden
Need a front wheel for a Craftsman 21 High Tunnel Mulcher, self propelled Model no. 917-377240
SOURCE: toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Posted on Mar 18, 2009
SOURCE: Spark Plug setting for craftsman 21'' mulcher push mower
Found a Manual from sears, thank you
Posted on Mar 20, 2009
  • 86 Answers
SOURCE: replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
Posted on May 12, 2009
SOURCE: how do you remove the driven wheels on a craftsman self propelled mower
On mine (front-wheel drive, about 8 years old) you first remove the plastic hubcap from the front wheel - then there's a big nut holding the wheel on. The hubcap just pops right off. I used a skinny, regular screwdriver to do it.
Posted on May 22, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
I NEED TO KNOW HOW THE BLADES GO ON A 21' SELF PROPELLED MOWER THAT IS A MULCHER
Most lawnmower blades simply attach with a bolt through the blade which bolts into the bottom of the crank shaft. The blades usually have a curve at the end of the blade, and this curve would point up when properly installed. If you post the model number of the machine, I can probably point you to a schematic which will show exactly how your blade mounts.
Tim
Oct 24, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Wheels will not turn on craftsman rear bagger lawn mower
Is the lever pushed up where the self propelled should be engaged? Yesterday, my wheels stopped turning. I have a break in the cable that goes to the self propelled. I will have to replace the cable.
Mar 27, 2010 | Garden
Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Aug 16, 2009 | Garden
I need replacement wheels for selfpropelled (front)power pro
You can go to searspartsdirect.com and enter your model number. Your mower is made by the same factory that makes the Craftsman mower so they should have it listed and you can order the wheels from them.
Jun 14, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
