Question about Samsung LN46A530 46 in. LCD HDTV
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about 4 of them. The picture will sometimes come back as if it has been spread across the screen with a squeegee, does that make sense? If I shut the TV off and wait a short time, then turn it back on, the picture is fine for a while.
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Posted on Aug 25, 2010
  • Mobonzo Aug 25, 2010
    Sorry that wasn't a solution. I am new here and didn't look carefully.
SOURCE:
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
My monitor goes dim after a few minutes. When you switch it off and on again the dsplay is ok then becomes so dark
How dim is dim? If the picture is still visible just like half as bright then your have backlight tube problem and unit LCD needs to be replaced, not worth repair price. If the picture goes out almost to a black screen where you can just bairly see a faint image then you hold the screen just right then you have a backlight inverter issue. If the problem is the inverter then you should be able to replace a few parts and get your unit back going. If you think you can open the unit up and maybe solder a few parts then I would open the case and look for bad capacitors on the power supply board. I can send you pictures of what to look for if you are interested. We also have a repair service for those units, most power issues run $15.00 plus shipping. Let me know if you need help opening the unit and checking parts.
Jun 17, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
LCD TV picture screen very dark
I have the same issues with my Westinghouse LCD set. I've found that going into the settings (using the TV remote) I can get it back to a bright picture by selecting 'restore factory settings'. It is aggravating and a pain, but I can correct it.
It only seems to do it on the analog stations, not the digital (HD) ones, so maybe it will go away after the conversion next year.
Hope this works for you.
Feb 18, 2008 | Televison & Video
Samsung LN46A530 46 in. LCD HDTV Logo
800 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
