Question about Eizo FlexScan F 931 (Gray) 21 in.CRT Conventional Monitor
EIZO F931 after switch on doesn't work. The power led blinks periodically 2 times green and then 3 times yellow. It looks like an error code. Could you help me? What does it mean? Do you have some instruction to repair and schematic diagram of this model?
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
TROUBLE SHOOT LC-60E78UN TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 30, 2016 | Sharp Televison & Video
What does Sharp TV LC-60C52U error code, 2 green power flashes and 3 green opc flashes mean?
Apr 02, 2016 | Sharp Aquos Televison & Video
I have not picture.
Jan 23, 2016 | Televison & Video
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
second.
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Sep 13, 2009 | AMD DURON,1.2GHZ,1200MHZ, FSB200Mhz ( OEM...
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
Eizo FlexScan F 931 (Gray) 21 in.CRT Conventional Monitor Logo
117 people viewed this question
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ShadeTek
ShadeTek
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
