Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
You turn the hd on and it just blinks on and off. this unit has hardly been used.
  • 11,800 Answers
The hard disk inside had died - and all it has needed for this to happen was just a shock.
Posted on Aug 21, 2010
Loud pop, dark screen, three blinking red lights
capacitor in the power unit has blown up.
i hope you have a warranty, if not you can call around see if any one repairs these units, you could call the manufactures customer service line see if the have authorized dealers to service there units.
most of the time the cost of labor and parts it mite be cheaper to buy new one, this depend how old this unit is.
check with the credit card you used, did you buy the extended warranty, where you purchase it will have service provider for that unit.
Oct 06, 2015 | Panasonic TC-P60UT50 60" 1080p 3D Full HD...
It doen not turn on completly. The green light blinks about every 5 seconds but doesn't turn on.
it is not getting enough power. Use a two ended USB plug (both ends into computer) one into HD, or use external power adapter
Jul 10, 2011 | Western Digital My Book Essential Edition...
External Harddrive does not work
Hi:
Hitachi hard drive are junk they are poorly made, but here is an option the could by a bigger hard drive and install it in the External case they are all the same, first take out the old HD from the case and take it with you to the store and purchse the same connection type wether its IDE or Sata and install it in the case, the cases are universal and all most all 5-1/4 inch HD will fit in the case is does not have to be A Hitachi Brand any brand will fit, I recommend a Seagate HD.
Apr 21, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Setting HD as secondary
ok easiest option to do this is to buy a USB Hard Drive Caddy.
Click Here
Then you just insert the HDD into the caddy and plug it in via usb and you will have access to all your files unless your hard drive is corrupt :)
Hope this helps
alex
May 08, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Turns on but nothing else
I have been using this hard disk for about 6 months now. It stopped working. The power and the usb cable are connected. I use Windows Xp and it doesnt read it. And for some reason most of the time when i open 'my computer' and the hard disk usb cable is plugged in 'my computer' stops responding !! However the 'safely remove disk' icon comes on the task bar and i can remove it from there. But i cant read it from explorer. The light on the HD keeps blinking. It reads my friends HD and flash drive. Please help me.
May 23, 2008 | Western Digital My Book Essential 500GB...
Lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Sony WEGA 36" Trinitron HD
Check for unit posting any blink codes on the timer LED. Google "sony blinking codes" for the explanation. Try turning unit off for 4 hours to force a hard reset of your set, you need to unplug it. Sounds like a low voltage problem in the HV circuit.
Oct 29, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
37 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Falling star
nuhu ibrahim
nuhu ibrahim
Level 1 Expert
John Lavis
John Lavis
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
