Question about Toshiba Satellite 1805-S204 Notebook
Wen i conect my compuer only de power light comes on.day before i working normal and i switch off normal.
    Sergeant:
  • 238 Answers
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Posted on Aug 21, 2010
Been driving a 2005 Chevy Colorado Z71 3500 Vortec Inline 5 for 4 years. My check engine light started popping on. the code told me the coolant temperature sensor was goin out. Took it to the shop and they...
its normal enough, but the coolant temp., sensor should have been replaced as well, was this done ? this sensor is critical to engine performance, air/ fuel mixture & idle, while engine warms up, it may also turn on rad fans, all the engine sensors work together to make sure engine performs as required. it doesn't just take temperature.
Jan 31, 2013 | 2005 Chevrolet Colorado
My digital dash blacks out when ever the lights come on all the fuses are working
check pin conection at electronic control module ,the brain,use electric cleaner at pin conecters.
Aug 21, 2011 | 1993 Mercury Grand Marquis
Is there a fuse connected to alternator that can prevent it from charging
there is no fuse on an alternator, but if the charge light bulb on the dashboard does not light up when the key is turned on to ign and go out when the engine is started, then the alternator primary coils will not get power and the alternator will not work. changing the bulb will normally cure this particular problem.
if the light does come on and go out as described, then the problem is an internal fault in the alternator
Feb 26, 2011 | 1991 Mitsubishi Eclipse
Wen i power switch my PS3 red light comes on then wen i pressed down once to get in on beeps once, then green light comes on for a second then yellow light to a steady BLINKING RED LIGHT!!! And does NOT...
This is called the yellow light of death. Cause is sever heat damage to the internal components. Either send it in for repair or replace. Sorry about this but the truth is brutal.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
No service engine soon light
check the bulb in the dash after all its a chev
Apr 28, 2009 | 1994 Pontiac Bonneville
Can't turn my compuer on
Check on *********** board that your CMOS jumper is in normal mode otherwise change it - also check any beep sound aswell as you remove all the cables ie.. IDE cables, front panel cables I mean only the 2 power cables to the motherboard and try to start the pc by shorting the power switch pin with a screwdriver see the display coming or not ????
IF it is a branded pc - you have to buy the same companies motherboard, normal motherboard will not work with branded pcs.
Sep 27, 2008 | Dell (S423) for Dimension 8100 (3F546)...
Enabling wma
Format the memory stick and restart the psp if that doesnt work, get a custom firmware wen installed www.dl.qj.net[ 3.40.oepreferrably] . Switch off the psp hold R trigger and switch on wen the recovery screen comes on, enable it form there.
Dec 13, 2007 | Sony PlayStation Portable (PSP) Console
Toshiba Satellite 1805-S204 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
