Question about Cameras
Outdoor pictures are very light, no color with horizontal bands. The indoor pictures are spotty, some ok, others blurry, some with the banding but there is color
  • Anonymous Aug 23, 2008
    I've reset the camera to default settings but it didn't help. Indoor pics are fine (with or without flash) but outdoors are hugely overexposed (camera in Auto mode). The only way around it I found is to zoom in slightly wherupon everything returns to normal. This may be particular to the fault in my camera but it's worth a try.
  • MolotovX Apr 25, 2009
    Same problems. Horizontal bands of color, rest is white. Called Polaroid because I have had the camera for 4 months and now I get to pay to ship it to them for warranty work. Yay!
    New Friend:
  • 14 Answers
.try xperimenting with diff pc settings wen shooting outdoors...also chk the white balance settings/////focus the camera on the object u want to appear white and "ok" it....chk the iso settings for light sensitivity....if all dis dusnt wrk ...theres a prob wuid ur ccd sensor..and can be repaired only by the service centre.
Posted on May 03, 2008
Is dual band booster is supported for Australian mobile band network?
Yes, dual band booster is supported for Australian mobile band network. It can be used for an outdoor direction aerial or for indoor spaces like home. This is the same style aerial supplied comparing other network system. The antenna can be set in an all-weather casing. The high gain system panel is perfect for wall-mount applications. This antenna works the 850MHZ, 900 MHZ, 1800MHz and 3G 2100 system frequencies (Australia and NZ telephone arranges) and is good with most portable sponsor packs.
Mobile Phone Signal Booster Best Signal Repeaters in Australia
Apr 18, 2017 | Dual Cell Phones
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
It says my wireless capability is turned off
http://ca.asus.com/product.aspx?P_ID=QAVTJThr36Jox9Cf
i dont know what your OS is ..?
go to that link and select DOWNLOAD, then your OS --downoad the manual , Version E5092
Wireless Operation Channel for Different Domains
N. America 2.412-2.462 GHz Ch01 through CH11
Japan 2.412-2.484GHz Ch01 through Ch14
Europe ETSI 2.412-2.472 GHz Ch01 through Ch13
France Restricted Wireless Frequency Bands
Some areas of France have a restricted frequency band. The worst case maximum authorized power indoors are:
• 10mW for the entire 2.4GHz band (2400 MHz-2483.5 MHz)
• 100mW for frequencies between 2446.5 MHz and 2483.5 MHz
Channels 10 through 13 inclusive operate in the band 2446.6 MHz to 2483.5 MHz.
There are few possibilities for outdoor use: On private property or on the private property of public persons, use is subject to a preliminary authorization procedure by the Ministry of Defense, with maximum authorized power of 100mW in the 2446.5-2483.5 MHz band. Use outdoors on public property is not permitted.
In the departments listed below, for the entire 2.4GHz band:
• Maximum authorized power indoors is 100mW
• Maximum authorized power outdoors is 10mW
Departments in which the use of the 2400-2483.5 MHz band is permitted with an EIRP of less than 100mW indoors and less than 10mW outdoors:
Jan 11, 2011 | ASUS K52F-BBR9 Notebook
I own cannon G9. I fail to get good sharp open outdoor pictures at night especially in place not well lighted. Do I all the time have to take pictures Manually to get sharp pictures as we do with focus...
If you have tried using the auto setting and it is still doing the blurry pictures it sounds like a problem with your camera not the settings themselves.
This blog http://www.teleplancamerarepair.com/camera-repair-blog/post/Got-Blurry-Pictures-Blurry-Image.aspx suggests a couple of the reasons might be:
"When your image appears distorted and with altered colors, in most of the cases there are two possible reasons:
- The internal shutter gets stuck , does not open completely or
The image sensor is damaged.... "
Jul 01, 2010 | Cameras
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
Jul 26, 2008 | Konka KDL32AT23U 32 in. LCD Television
Fogging Picture
try to use the zoom function during picture preview and you will see the horizontal bands. Time to change to a new CCD i guess..or maybe a new camera :-)
Mar 10, 2008 | Casio Exilim EX-S500 Digital Camera
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Only see a slice of picture + bright horizontal band
you could do three of these change flyback change yoke change cap that couple the horizontal transistor.good luck
Apr 27, 2007 | Toshiba 27A33 27" TV
Cameras Logo
108 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
