Question about Whirlpool LER4634J Electric Dryer
Ryer starts on its own - Whirlpool LER4634J Electric Dryer
It sounds like the timer switch motor does not "turn OFF" and keeps running through the next dryer cycle. The "Start" switch may be stuck "ON" all the time. If it is a mechanical switch, try pressing it several times to "free it up". If that doesn't work or it is solid state (electronic), it may need replacing. A meter (ohm meter) can be used to tell if it in "always ON" (near zero resistance). Be sure to remove power from the circuit (un-plug it from the wall or disconnect batterys) before using an ohm-meter.
Posted on Aug 23, 2010
Maytag Neptune MDE5500AY Electric Dryer my Maytag ryer will not start.....sometime it take 20 pushes of the start button before it will start
Hello, tyrone I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Feb 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Clothes have to be dried several times before getting dry
The first thing to do is to remove the ryers exhaust venting tubes and clean them out thoroughly. Any lint build up will cause the moister sensor to keep the heat in check. It is a saftey device to prevent home fires from clothes dryers. Just on small clog will do this. If cleaned and still no heat listen for a clicking noise upon starting. If no click is heard the Spark ignitor is at fault. If it is clicking the moister sensor is at fault
Jun 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Ryer not heating
If you have 110v from the timer connection to the element and ground, that is normal. You should have 240v between the two element connections. If you do, and the element is not hot, disconnect the wires from the element and check the continuity of the element. If you don't, check back thru the wiring until you find 240v. This test will show you where the fault is.
May 05, 2009 | Dryers
Problem with Whirlpool Duet gas dryer
Hi I have the same problem
Bypassed the hi limit switch and it runs fine
service teck replaced board,thermistor, all vents,gas coils , flame sensor and glo coil andf all with no luck. Unless it is bypassed thed ryer will only stay on 5 to 6 seconds on gas cycle
If i plug my old dryer in and hock up to gas and vent it works fine
So im using my old dryer and this peice of **** is sitting beside it as Im not going to run this without the safety thermostat
If you find out please let me know
Jan 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer handle replacement - Kenmore Elite
E-mail me the model number of the dryer and I will be able to find you the information you need. robert_fawbush@yahoo.com
Apr 08, 2008 | Dryers
Dryer turns off
Is the dryer shutting off completely or is the burner going on and off erraticly? If it is the burner you probably have a faulty coil on the burner. There are two electric coils mounted on the burner. You can buy both of them in a pack cheaper than buying one by itself. Remove the lower front cover and you will see the coils on the gas valve with wires going to them. Remove the wires and bracket that holds them down and install new coils. They are made so that you can't mix them up, they only fit one way.
Oct 08, 2007 | Dryers
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
