Question about GE Spacemaker JVM1640SJ Microwave Oven
My microwave started making a humming noise and won't work. The light doesn't come on either. I've tried unplugging it and plugging into a different outlet. Still doesn't work. It's getting power - the clock works. It's a GE Spacesaver XL1800. Any solutions?
  • GE Master
  • 9,047 Answers
If it's humming all the time, it may be a bad electrolytic capacitor on the control circuit board. We repair these all the time for $39.95 postpaid.
I'd first make sure it's not cooking when it's supposed to be off.
Just put a cup of water in it, shut the door, and let it set for a minute. Then see if the water's warmer.
If it is warmer, unplug the oven until it's fixed. That's probably a shorted relay on the control board, which we can also fix.
If it is not warmer, I'd bet you need the control circuit board repaired or replaced.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you want to check the price of a new circuit board, enter your full model number here.
Let me know if I can help you further.
Posted on Aug 23, 2010
Magic Chef MCO153UBF microwave
There are two things that come to mind, the magnetron is starting to fail, or the strapping has come loose on the fan motor housing, unplug microwave oven and remove top, [several screws] carefully inspect the fan for any loose mounts and tighten.
Jun 09, 2012 | Magic Chef Microwave Ovens
Microwave buzzes when off
This is the power transformer humming, sometimes when transformers get older you get vibrations in the windings due to magnetic fields generated within the transformer which causes the humming noise, It's more annoying than anything and won't affect the operation of the microwave.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Hi when i set the microwave at 100 watts for 1 min it starts and stops working by itself when timer reaches 38 sec and it also dosent make the beeping sound in the end.please help
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
Aug 31, 2011 | Bosch HMT9656GB Microwave Oven
Microwave is making humming noise and started to smoke and stop working
sounds like the fan inside oven seized, causing the smoke and popped the internal fuse. If you have any appliance repair shops around, they should be able to fix it for you cheaper than replacing the entire unit. Make sure you leave it unplugged, I know thats abvious but had to mention. Good Luck!
Apr 18, 2011 | LG LMV1630ST Microwave Oven
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Contant humming noise, even when not in use have to unplug in order to stop the sound.
The constant humming noise you hear when the microwave is plugged-in but not running is caused by the Low Voltage Transformer, which is located inside the back wall of the outer cabinet on the left side. If the microwave is working properly otherwise, there is no hazard, just the annoying noise.
To access the transformer, the microwave must be taken down and the outer cover removed. The transformer is held to the back wall of the cabinet with four screws, and there are two sets of leads with pull-apart connectors. The noise is the result of 60hz vibration being transmitted to the sheet metal from the transformer which may not have been sufficiently "potted" or otherwise mechanically isolated when manufactured. You can either replace the transformer or try wedging some thin rubber or other material between the transformer and the sheet metal to quiet the noise. Just be careful to not damage the windings!
Oct 31, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I replaced the light bulb, now it displays -F6- and pushing any button causes a humming noise.
I left the unit unplugged over night, plugged it back in the next day and still had the same problem.
Oct 13, 2008 | Roper Microwave Ovens
Humming sound when off
I also have the same microwave model and with the same problem. It is not quite 2 years old. I have a service call scheduled but did e-mail customer service at Whirlpool to inform them of this. Sounds like it could be defective model and a fire hazard. You should also inform them of yours.
May 15, 2008 | Whirlpool MH3184XP Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
105 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
