MITSU WD73733IT WILL POWER ON BRIEFLY AND THEN SHUT RIGHT OFF, AND THE ORANGE LIGHT IS ON CONSTANTLY EVEN WHEN THE GREEN POWER LIGHT IS ON. i SAW IN THE OWNERS MANUAL THAT IS A OVERHEATING PROBLEM, HOWEVER IF IT SITS ALL NIGHT OFF AND I TURN IT ON IN THE MORNING IT WORKS FOR ABOUT 15 SEC. AND THEN SHUTS DOWN. I HAVE DONE THE SYSTEM RESET AND THAT DIDNT HELP. THATNK YOU IN ADVANCE
  • toyotadr Aug 21, 2010
    So just open her up and take a tester to it? Would there happen to be any type of fuses?
  • 11,800 Answers
In that case the fan has stopped working. You must open the case and try to find out why: the fan itself is faulty, the connections powering is are loose, the power source is faulty.
Or maybe the thermistor located on the tubes has been burned or shorted.
Posted on Aug 21, 2010
  • Azrael SRL Aug 21, 2010
    Yes, there are 5 separate fuses, but they burn only if the part they are powering has got a fault that has caused the current to raise dramatically - like a short. You need to do those tests. If you don't know how to interpret the indication of the multimeter or how to find a failed part then it's time for a pro.
I'm installing a pioneer deh- 2750mp cd player into a '92 Ford Laser, and was wondering how the wire colours match up?
Hello! Ford wiring
Power
Constant +12volts Green/Yellow
Switched +12volts Yellow/Black
Ground Red
Power antenna Blue
Illumination Blue/Red
Speakers
Front Right + White/Green
Front Right - Green/Orange
Front Left + Orange/Green
Front Left - Light Blue
Rear Right + Pink/Blue
Rear Right - Green/Orange
Rear Left + Pink/Green
Rear Left - Pink/Blue
Guru..............saailer
Jan 22, 2010 | Pioneer DEH-2700 CD Player
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
1994 Ford Aerostar radio wiring
FORD up_arrow.gif P o w e r Memory (+12v Constant) Green Yellow Ignition (+12v Switched) Yellow/Black Ground (-) Black or Fat Red Illumination Orange Dimmer Orange/White Power Antenna Blue (varies greatly) S p e a k e r s Right Front (+) White/Green Right Front (-) Green/Orange Left Front (+) Orange/Green Left Front (-) Light Blue Right Rear (+) Pink/Blue Right Rear (-) Green/orange Left Rear (+) Pink/green Left Rear (-) Pink/Blue
Dec 15, 2009 | Car Audio & Video
Wireing diagram/coloring?
Yellow: Constant Power (+)
Red: Switched Ignition Power (+)
Black: Ground (-)
White: Front Left Positive (+)
White/Black: Front Left Ground (-)
Grey: Front Right Positive (+)
Grey/Black: Front Right Ground (-)
Green: Rear Left Positive (+)
Green/Black: Rear Left Ground (-)
Purple: Rear Right Positive (+)
Purple/Black: Rear Right Ground (-)
Blue: Remote wire
Blue/White: Antenna wire
Orange: Running Lights
Orange/White: Dimmer Lights
Nov 26, 2009 | Pioneer DEH-345 CD Changer
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Mercury cougar
Constant 12V+ Black/Orange Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Green Dimmer n/a Amplifier Remote Dark Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Light Green Left Rear (-) Tan/Yellow Right Rear (+) Pink/Light Blue Right Rear (-) Brown/Pink
Sep 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
Bulb doesn't light
yip, sounds very familiar
steve, does the pj lamp try to fire up.
does it briefly light up then shut off
these are the typ. symptoms of an expired lamp
Feb 26, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
1999 ford explorer car stereo install
Heres the whole list. 1999 Ford Explorer Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Doors Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink (from the12volt.com) Best of Luck.
Sep 28, 2007 | Car Audio & Video
Open Questions:
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
