Question about GE Refrigerators
I have a model # TFX20JRXD WH side by side GE refridgerator and water is running into the bottom of the freezer side. What could cause that. Also the water dispencer does not work but the ice maker does. Does this kind of refridgerator have a filter that may need to change.
fridgetech
  • 473 Answers
SOURCE: Kenmore Elite Bottom Freezer Refrigerator
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
Posted on Nov 30, 2008
  • 5 Answers
SOURCE: I have ice forming in
probably have a clogged drain at the rear base of the freezer unit check at the very bottom of your freezer at the back look and see if the drain is covered with ice..
Posted on Jan 15, 2009
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
  • 72 Answers
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Posted on Jun 11, 2009
  • 145 Answers
SOURCE: frost build up in freezer (ice maker section)
Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
the is a easy way to adjust that but you are going to have to take
your ice maker out
then using a flat head screw driver remove the white square cover
you will see a gear and a adjustment screw and a lever like this
( - I + )
turn the screw to the minus sing a quarter way and install the ice maker back up.
Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
the ice maker feel up buy time not buy water level.
Posted on Jun 28, 2009
I have a side by side refridgerator , Lately after we open the frezzer side door and close it , After a couple of minutes water runs down from the bottom of the door
Ice inside freezer door is warming and melting. Some doors have fiberglass insulation and can be re-insulated (per a service bulletin from GE) but others have foamed in insulation which would require complete door replacement to correct that condition. I suggest contacting GE consumer relations with your model and serial number to see if they will help you.
Aug 09, 2011 | GE Refrigerators
My GE model tfx20jrxd is not getting cold on the refridgerator side but it is fine on the freezer side. There is some frost build up on the back wall of the freezer. Any suggestions?
you have a defrost issue. some problems
1. failed heat coil
2. failed defrost sensor
3. failed defrost timer
Please Rate/Vote this response. Thanks
Dec 20, 2010 | Refrigerators
GE model tfx26krda side by side refridgerator/freezer
If the drain catch tray is full the unit will overflow. Look underneath in the rear/fron of bottom the fridger to remove and empty the catch tray. If there is food or debris in the bottom of the fridge (drain grates) it will keep water from going down.
Sep 14, 2009 | GE Hotpoint Top-Freezer Refrigerator
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refridgerator leaking
it is possibe the inlet to the drain line may be plugged.The defrost water cannot run down the drain line to the pan on on the bottom.Also make sure it is level
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whineing noise\and leak on freezer side in the bottom of it
yes the water in the bottom is because your drain tubing is cloge thid is the small hole in the frezer area defrost your fridge use a wire to clear out the debri that clogs your tubing the water should drain in the pan where the compressor is thanks from gilles
Feb 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
