Question about Whirlpool AD65USL / AD65USM Dehumidifier
My unit runs constantly
My dehumidifier runs non stop, no matter what the setting it is on - and doesn't seem to fill up that quickly. I have cleaned it and set in on a level surface, any ideas?
Thanks
  • Anonymous Sep 02, 2008
    My Whirlpool dehumidifier has constantly been running but it doesn't fill up the water tank any more.
    Genius:
  • 1,073 Answers
Unit has a sealed system problem leak in one of the coils, a leak at the compressor, take it to an authorized whirlpool service servicer for a check
Posted on May 05, 2008
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
Dehumidifier seems to not be dehumidifying
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Jun 09, 2008 | DeLonghi Dehumidifiers
Makes a loud beep every minute or so. Doesn't seem like basket is filling with water either.
Turn the Master ON/Off Switch to OFF and unplug the unit. Remove the air intake filter and clean it. Allow it to thoroughly dry, before reinstalling it. Once the filter is thoroughly dry, reinstall it, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity level at 35% and allow the unit to run as you normally would. The beating should have stopped, since you cleaned the filter. Be sure to maintain at least 2 feet of clear air space around the dehumidifier.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 24, 2011 | Kenmore 54501 Dehumidifier
The dehumidifier runs, cycles on and off, but there is almost no water in the receptacle. I haven't had to empty it since it started cycling on & off this season. I usually have to empty it at...
You may have the humidity setting to high. Try lowering it to 45%. Or if yours doesn't have an LED Screen, set it for minimum. Also, check and clean the air intake filter, if you haven't already. Keep in mind, most dehumidifiers have a fan that may seem to run constantly, but the compressor doesn't turn ON. The fan is circulating air, in a effort to detect humidity levels that are higher than what you have the humidity removal set on.
Hope this helped you.
May 10, 2011 | LG LHD45EL Dehumidifier
Runs - but no water in bucket
Hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
May 02, 2010 | LG LHD65EBL Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
Humidifier runs but does not collect any water
Sep 14, 2009 | Dehumidifiers
Runs but doesn't collect any water
Aug 02, 2009 | Dehumidifiers
Unit runs but doesn't pull humidity out of room, filter clean
Possibly lost refrigerant from system- check warm air is coming out of machine. Otherwise it could be dirty filters, and not getting enough air over evaporating coil. Other than this, replacing parts is usually more expensive than buying a new dehumidifier :(
Jul 18, 2009 | Dehumidifiers
Dehumidifier does not fill up with water anymore
Oct 22, 2008 | Whirlpool Dehumidifiers
Whirlpool AD65USL / AD65USM Dehumidifier Logo
208 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
