Question about Harman Multimedia HS 300 System
Hi, The USB external disks greater than 250GB are not getting recognised in the system. Model : HS 300ME USB: tried western digital, segate. Regards, Utpal
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Harman Multi... Master
  • 924 Answers
The unit is apparently not designed to address any drive larger than 250MB. You might look on Harman's website and see if they have a firmware update for this. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 09, 2013
2 Suggested Answers
helen3047
SOURCE: I have a problem in
i can not play movie through usb on harman /kardon hs 300ME Kindly provide me solution
Posted on Feb 12, 2012
Wont recognize usb anymore
if the external hard disk drive powers on, perhaps replacing the USB cable could help ?
i had WD extrenal, and it crapped out on me -- i had so much vital information that i lost . i finally discovered that the power modeul inside the housing that encases the drive was bad.. i coul not get the PC board replaced.
i hope you can resolve this with new USB cable.
have you tried another computer -- see if that PC recognises the WD external drive
let me know how it works out for you
Nov 03, 2010 | Western Digital WD Passport 250GB Portable...
I can feel d disk rotating yet PC doesnt recognise the drive
Hi There mosam,
In most cases, external Passport Drives come with their own drivers and install themselves automatically when connected to your puter's USB port. If it doesn't find a driver, then the Passport can't work. Go to the Western Digital Support website and type in the model # of your external drive. Having located the driver for that model, download it by saving it to your desktop. Then run the exe. driver install software. Once having done so, your Passport should show right up and off you go! Very Important...if the driver install program wants you to restart your puter after installing itself, be sure to do so. Good Luck!
Apr 04, 2010 | Western Digital WD Passport 250GB Portable...
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
Western Digital external USB 2.0 Problem
Buy an External USB 2.0 Hub with the 5.0V power supply. I have a TARGUS 4 Port Hub. MY WD2500XMSB works fine thru the HUB, but will not work using any cable (even the one that came with it) when directly connected to the USB port on my computer. The power consumption of passports sometimes exceeds the .5 milliwat rating for the ports and ccause the port power to interrupt (see USB 2.0 specifications). The external hubs with external power have a higher power output usually an can power the passport drives. CW Rumsey
Oct 07, 2009 | Western Digital 250GB MyBook External USB...
Wd element 250gb usb hard drive
you'll find that the external chassis is buggered, get a new one and put the hdd in and see if your info is still there.
Apr 23, 2009 | Western Digital 250GB ELEMENTS EXTERNAL...
Western Digital 250GB External Hard Drive not working
there are a couple of reasons for this. Likely the drive has not been setup in Windows. Hard drives need to setup in Disk Management. Disk Management can be found under Computer Management in the Control Panel. After you run Computer Management, expand the Storage tab and Disk Management is located there. At the bottom of the screen threre is a listing of all drives (hard and CD) located in or attached to system... You will see your new drive listed, but not active. Right click on the new drive in the bottom window and Windows will prompt you on how to configure the drive. You'll need to activate so Windows can assign a drive letter to the drive, partition and format. Once this is done, you will be able to see and use the drive under windows.
I've attached a link from Western Digital that provides their FAQ response to your issue.....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1017&p_created=1055796499&p_sid=7R8631pj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0yMjgsMTAxLDIxOSZwX2NhdHM9JnBfcHY9My4yMTkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXJlY29nbml6ZWQ*&p_li=&p_topview=1
You didn't mention what type of connection it uses (USB, etc). According to Western Digital, if you have a USB External Drive, you should get a prompt to install drivers by Windows when a new device is installed. Similar for Firewire device.... Did Windows "recognise" the new device by opening a New Device Found window? If not, try using a different USB port and/or ensure the USB port is enabled in WIndows.... The Quick Start guides for all models can also be found from the link provided above.
Jan 24, 2009 | Western Digital 250GB MyBook External USB...
Westen Digital 500 GB Element....
please repair the drivers of USB by the help of CD which come with the Motherboard and try again
Jan 23, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Harman Multimedia HS 300 System Logo
Top Harman Multimedia Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
