Question about Dryers
Is there a pilot light on this dryer or does it have a glow light
  • Dryers Master
  • 43,501 Answers
You need to supply a model number to be able to answer that...
heatman101
Posted on Sep 12, 2010
Whirlpool dryer will not ignite.JET FLAME WILL NOT GO ON.
if the ignitor is lighting up, or if you have a actual flame pilot light, depending on the machine, if you have a pilot light, check the thermocouple that the flame from the pilot is supposed to heat , but thats on very very old machines , if you have a glow plug , ( a heat source that comes on electrically and glows , then you need to check the 2 coils that are on the gas valve, they have gone bad
Jul 13, 2011 | Whirlpool Dryers
Where is the pilot light on a fgr231as dryer?
How old is the dryer? New dryers do not have pilot lights they have electric spark generators or glow plugs.
May 28, 2011 | Frigidaire FGR231A Gas Dryer
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Maytag dryer pilot light
You might have a hot surface ignitor that if broken can fall off and be somewhat difficult to locate by sight having never replaced one before.
Look at the new parts base as thats all you may have showing.
The ignitor regarless of type is very close to the gas manifold temination
going into the combustion compartment.
Replacing the new ignitor BE CAREFUL not to touch or bump the ignitors surface or it may fry out before you leave! they break easily!
I would use magnetic nutdrivers, its either 1/4 or 5/16 inch on most everything, very handy for furnace and AC work too
Aug 25, 2009 | Maytag Dryers
Rewplaced igniter now dryer wont heat up
The dryer has electic 'eyes' to keep the burner from coming on if the pilot is not lit or the glow plug fails to come on. Be sure the windows to these 'eyes' are clean and in line with the light source (glow plug or pilot flame) that they are intended to sense.
After you replaced the glow plug, does it come on at the start of the cycle?
Aug 21, 2009 | Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Lighting the pilot
there is no flame type pilot. when you turn on the dryer remove small cover on lower left front panel to view if you see a orange glow, which means your ignitor is getting power listen for 1ckick sound and then a second after the ing glows. there a few things that could be bad ignitor. soleinods on the gas valve or a bad thermal fuse
Dec 19, 2008 | AEG T57800 Electric Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Frigidare laundry center model FLSG72GC
it doesn't have a pilot light has a glow bar and a safety solenoid probably the glow bar needs replacing its on the side of the burner tube there is an slanted acess panel under the drier door
Jan 27, 2008 | Dryers
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
