Question about Dell Inspiron 1525 Notebook
Overheat shut down - Dell Inspiron 1525 Notebook
    Scholar:
  • 166 Answers
Please do the following:
1.Update the BIOS/Firmware of your notebook through the manufacturer's support site.
2. If it still persist, and still under Warranty, contact manufacturer's tech support, usually replacing the heat sink and fan resolves the issue.
3. Furthermore, you can attached a cooling mat or fan.
4. If your system is no longer under Warranty, you can have a local tech cleanup your fan and re-apply the appropriate thermal past.
Please post your comment if the information has been helpful which will be helpful in improving my support assistance. Thank you and regards.
Posted on Aug 22, 2010
Why does it overheat and shut down?
A common overheat induced shutdown on Fords is the ignition module, although any number of things can cause this . Does it get spark when it shuts down or can it fire right back up ? What year Cougar ?
Nov 20, 2015 | Mercury Cougar Cars & Trucks
I have a prolectrix wall mounted bowed fireplace model BG-D4. The fan quit working and now it overheats and shuts down. Is there a fuse or a reset button?
I don't know this specific product but if it is designed to run with the fan, it will overheat if the fan stops and shut down. Often, the shut down is by a thermal cutout, so just wait for it to cool dow.. You may have to remove power.
Jun 23, 2014 | Heating & Cooling
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
Oct 10, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Affinity dryer model FAQE7001LW0 OVERHEATS AND SHUTS DOWN
Therm o resistor or air ducts venting needs clean out
if not that change main board
Aug 13, 2012 | Frigidaire Affinity FAQE7001LW Electric...
Laptop Overheats
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 16, 2012 | Computers & Internet
What is the ploblem if the car shut down when its hot
It is supposed to shut down when it overheats, that is a safety precaution to save further damage. You fix the overheating problem and it won't shut down anymore.
Dec 12, 2010 | Daihatsu Charade Cars & Trucks
The laptop overheats and then shuts down
Hi joshua1156,
Your laptop fan is not working. That's why the laptop overheats and shuts down. Replacing the fan will solve your problem.
Thank you for using fixya,
Arun Zac
Nov 26, 2010 | Gateway 7320GZ Notebook
Toshiba satelite P105 laptop pc problem: overheats and shuts down automatically. while in use. What are the causes of overheating?
Normal 0 When a CPU chip overheats it shuts down (thermal overload) and won't boot up again until it has cooled down. If this problem is not fixed, then eventually the CPU chip will fail. This fault is either a faulty fan or the fan and heat sink assembly is clogged with dust. Please click on this link and follow my instructions to fix :-
http://www.fixya.com/support/r5959377-overheating_computer
Oct 16, 2010 | Toshiba Computers & Internet
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
Built in oven keeps shutting down for no known reason
there is an overheat stat and this is probably coming into operation.
check casing fan is operating - not the fan inside the oven - and check there is plenty of ventilation for the appliance
Oct 11, 2008 | Frigidaire Kitchen Ranges
Dell Inspiron 1525 Notebook Logo
183 people viewed this question
Alun Cox
