Question about Kenmore 62982 Electric Dryer
How do you get the bottom panel under the door of the dryer off? It looks like there are clips of some sort there, but can't remove or move the clips enough to remove the door? please give step by step instructions. Kenmore electric dryer purchased in 2003 model # 26 62982 thanks for your assistance,
    President:
  • 1,554 Answers
Unplug the dryer before attempting any repair works.
The bottom front panel is secured to bottom of the top front panel by two securing clips. Insert a flat-bladed screwdriver between the top front panel and the bottom front panel as shown then pry the panel out then lift it off the cabinet.
Install the bottom of the bottom front panel first when reinstalling then push the top back into position until the clips engage.
Posted on Aug 22, 2010
How to remove my rear interior door panel on a Saturn 2007 vue.
This takes a special tool that you get from an autoparts store. If you don't use that tool you break all the clips or you tear the compressed backing on the door panel. The way to use the tools is slide it under the bottom lip of the panel. move it to the left or right till you hit a clip, then you pry the clip out. The tool looks like a two prong fork. The forks fit around either side of the clips to pry them out of the door. You do that all the way around the bottom of the door edge. Then you make sure that the ***** that maybe present holding the arm rest or door handles are removed and you lift the bottom of the panel up and away and it comes out of the wind slot.
Apr 05, 2016 | Saturn Cars & Trucks
The belt has snapped I have had a look inside but can't work out the best way to replace the belt
I have included a link to the pictures of the routing of the belt.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 16, 2011 | Dryers
My dryer is about 3 years old suddenly won't dry a load in one cycle. Recently moved and moved the dryer with. Haven't had any problems.
Installing the belt
facing down.
Please RATE me
Jan 15, 2011 | Kenmore 500 6952 Dryer
How do you replace belt on dryer
Installing the belt
facing down.
Please RATE me
Jan 03, 2011 | Kenmore 62602 Electric Dryer
How do I remove the top of a Frigidaire dryer - model GLEQ642AS2
I will include the instructions for replacing the belt, it will include the top removal and also a link that you can click on the see the belt routing.
Installing the belt
facing down.
Please RATE me
Jan 01, 2011 | Frigidaire Dryers
Replace dryer belt
Installing the belt
facing down.
Please RATE me
Dec 31, 2010 | Whirlpool LER4634J Electric Dryer
Are there 4 support rollers? Instructions on how to replace them. Thanks - Doug
Now you can replace your drum rollers at this time
Installing the belt
facing down.
Please RATE me
Dec 22, 2010 | Kenmore 800 7983 Dryer
HOW TO I GET INSIDE A NEPTUNE DRYER MODEL 9700 TO FIX A FUSE
Unplug the unit.
Remove the top panel(two bolts in the rear metric 10 or Phillips will work) There are four screws across the top front of the control panel remove those and the panel will swing out and down,move it back and forth while pulling upward it has plastic clips on the bottom that keep it in place.follow the wires from the panel to the control board and unplug them or you can just lay the whole panel on top of the unit.
Open the dryer door and remove the two phillips screws on either side at the bottom of the door opening,then remove the four screws across the top of the panel it will lean out toward you,unplug the door/light switch and lift the front panel off the bottom clips.
You're probably looking for the thermal fuse located in the plastic elbow of the blower housing at the bottom of the unit it will be the round metal disc with a brown or black plastic backing.check your vent going outside and make sure it is completely clear/open doesn't have to be spotless clean but if it gets restricted in any manner it will blow this fuse.
Sep 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Need help with dryer repair.
open door top of door under lid remove screws lift lid more screws on sides that hold front panel on remove also lift front panel off...go to back remove 2 panels bottom one off undo belt panel 1/2 way up remove the re move e clip and washers now you can pull drum out the front watch wires on front pane..l wink.. smile... and 2 thumbs up i hope you have it unplugged hi hi
Aug 11, 2009 | Dryers
GE dryer is getting louder when running
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one, if the dryer is the open drum type,
Oct 17, 2008 | Dryers
Kenmore 62982 Electric Dryer Logo
256 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
