Question about Compaq Presario 5000 PC Desktop
Compaq Presario 5LOXE1 Memory upgrade
Have 2 memory slots with 2-256mb memory cards - bought 2-512mb memory cards to upgrade. Problem is each 512MB card will work seperatly but not together.
System Rom 686P9 v1.01
Mother Board 1R1741 VerA317839
SN 253888 101730NR
Using F10 unable to find how to change the BIOS..
Any help
  • fstreine May 06, 2008
    No solutions -
    Have tried all combinations of memory boards
    Know how to seat the memory cards - not an issue
    to get to the BIOS screen on my PC is F10
    Try again
  • Compaq Master
  • 13,433 Answers
Hello fstreine
Most likely a compatibility issue, does it work if you put in one 512 and the other 256?
if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
Posted on May 04, 2008
  • Ekse May 04, 2008
    to get into bios you need to press either f2 or del button in the startup, but there isn't much you can do in bios about this issue.
  • Ekse May 06, 2008
    fstreine
    you already accepted coolguys solution, no point in trying.
    Genius:
  • 3,422 Answers
So you mean only 1 video card is working and the other one is not?
  • 1 more comment
  • Priya darshan May 04, 2008
    I mean memory* card.
    OK try this out..Once you restart your PC keep hitting F2 repeatedly.You will get the BIOS screen.If not try out the same with F8 or F12.You can also try hitting the DEL key repeatedly.
    Another thing..Check if both th\e RAM cards are properly inserted in the slot.Remove and fix it again.Make sure it is tight and the two clips have locked the card when you have inserted them.
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
What's the maximun of ram memory that compaq presario 6025ea can admit?
This is an older model computer, and therefore it can't utilize the large amount of RAM that more current models can.
The Presario 6025EA has two DIMM slots and comes with 256MB of RAM installed. The maximum amount of RAM that can be installed is 1GB. To upgrade to this, you will need two 512MB DDR-266 (PC2100) RAM modules.
If you found this solution helpful, please leave a positive rating!
Jul 07, 2011 | Compaq Presario V6014EA V6016EA V6024EA...
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
Thinkpad T20 won't accept memory upgrade
according to ibm
you are allowed only pc100 memory with a maximum of 512mb.
when handling memory make sure you are grounded before touching any memory chips.
try getting another set of 256mb chips and grounding yourself before installing them.
Mark
May 15, 2009 | IBM ThinkPad T20 2647 Notebook
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
Want to replace 2x 256mb of memory with 2x 512mb of memory into my hp compaq presario v4000
Hi there.
Yes you can upgrade the memory to 2 x 512MB DDR SDRAM memory.
You will be pleased to know that the system supports up to 2GB DDR SDRAM memory (2 x 1GB)
Please be gentle when installing the new memory taking care to remove the battery and the mains power from the laptop first before installing.
Have fun and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq Presario v4000 Notebook
Memory upgrade
The M45-S169 only has one available memory slot.
(I'm confused about your post that states "M45-S265" in the head line).
  • Configured with 512MB DDR SDRAM (both memory slots may be occupied)
  • 512MB(min)/2048MB (max), 256MB on-board memory with 1 available memory slot for 256MB, 512MB, or 1024MB PC2700 DDR 333MHz SDRAM 2.5V SODIMM memory modules
You can find the complete specifications here.
Jan 05, 2009 | Toshiba Satellite M45-S265 Notebook
Upgrade ram
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
May 22, 2008 | Compaq Presario M2000 Notebook
Problem with amount of RAM.
maybe your video card uses 128mb shared memory so 128 for video plus 640 reading equals 768.
Apr 10, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
95 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
