Question about Logitech Computers & Internet
Hello I have a problem with the mouse, it is wireless and the green light links all the time with no movement
    Problem Solver:
  • 8 Answers
On the bottom of the mouse or keyboard there is a tiny button when u push button on the dongle or wireless adapter u must also click the mouse or keyboard so they can find each other also make sure you have really good batteries
Posted on Aug 21, 2010
I've had my Arc wireless mouse (model 1350) for about 5 months now. I have replaced the battery twice since I got it...most recently a day ago. The second battery replacement causes a green light to...
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall
hope this helps
Oct 12, 2010 | Computers & Internet
My house will not move the pointer or click on anything. When I plug it in, the device manager recognizes it as a mouse and it connects without fail; I simply cannot interact with anything on the desktop.
ok here goes, make sure you loaded the cd that was included in the box. i want you to search and get rid of the old mouse driver. then check the transmitter for the wireless mouse make sure the lights are lit. Does the snap in reciver have its green light lit. turn over mouse make sure the light is green while in bottom of mouse. download link for software. you didnt say but if your using windows 7 it is differant drivers so check this link out
http://www.microsoft.com/hardware/downloads/default.mspx
but truthfull i think it is recognizing the mouse yes but is using the drivers from your old mouse.
if this helped please spend a moment and rate it to let us better help you
Mel
Sep 27, 2010 | Microsoft Wireless Mobile Mouse 3000
Spyder won't respond
try cleaning the laser of the mouse. the light spot at the bottom it mite have some dirt or something on it thats not alowing it to have a good conection
Dec 14, 2009 | AVENUES The SPYDER SwissGear Wireless...
What are the Pros & Cons between a ''Optical Wireless Mouse'' and a ''Laser Wireless Mouse''
The difference between a regular optical mouse and a laser mouse is the light used to track movement. A regular optical mouse uses an LED light in the optical engine, while a laser mouse uses a laser to track movement. The more dots per inch (dpi) a mouse can track, the more sensitive and accurate it is. A typical optical mouse tracks between 400dpi and 800dpi, while laser mice track more than 2,000dpi. Neither is really better; it all depends on your needs and preferences. Unless you're a gamer or a graphic artist with a need for precise movement, you'll probably find a 2,000dpi laser mouse too sensitive. Many gaming mice, however, allow you to switch sensitivity levels so that you have precision when you need it but can revert to 400dpi or 800dpi for regular mousing. Besides their tracking speeds, laser mice work on nearly every surface, whereas optical mice may experience trouble tracking on black or shiny surfaces.
Nov 27, 2009 | Computers & Internet
My cursor on the screen will not respond to the movements of my mouse. 1) the green light on the USB receiver is green and not flashing 2) there is red light on the bottom of my mouse, indicating power
Still change the batteries even tho you have a light on. These things get funky when power is low.
if that doesn't do it, un plug the adapter and re place it,then reconnect devices.
Nov 20, 2009 | Microsoft Wireless Mobile Mouse 3000
My dell wireless keyboard doesn't work the mouse works. They are linked into the same USB reciever. There is a red light for the keyboard and green for the mouse....I have tried all windows diagnostics,...
try to delete the Bluetooth keyboard and mouse, then search/create a new device and see if they are detected. if yes, just follow the instruction on installation. else, there could be a problem on either of them. hope this helps
Oct 31, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Optical light on Mouse not working
maybe the battery?
follow the steps below to troubleshoot the mouse
Wireless mouse does not respond (generic instructions)
Try to Resynchronize your device with the receiver(connector)
Follow these steps.:
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse at least 6 feet away.
1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
2. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
3. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 3 again.
For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
or
Try different port and restart your computer.
or
Reinsert the batteries or install fresh batteries
If you have the possibility check whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
Sep 06, 2009 | Microsoft Wireless Notebook Optical Mouse...
My Logitech wireless mouse is not tracking consistently.
hello,have you tryed cleaning the bottom of your mouse any dirt of debre can cause a bad mouse curse movement also have you checked to make sure you have updated drivers for your logitech devises ?
Mar 31, 2009 | Logitech Wireless Access Duo Optical...
MOUSE LIGHT FLASHES red and green; does not function
The flashing red and green lights means that now it's in discoverable mode and it's time to add it as a bluetooth device.
Mar 14, 2009 | Microsoft Wireless Laser Mouse 5000
Red light
If you're talking about the red light on the bottom of the mouse, it is needed for the mouse to track its movement. When the mouse is not being used, this red light blinks only once per second or so to save power, but once it sees movement, it will come back on.
Aug 17, 2007 | Logitech RX600 Mouse
Computers & Internet Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
