Question about LG WM-2277HW Front Load Washer
My LG washer keeps displaying DE and makes door clicking noise and if it unlocking the door and will not start a cycle. We have bought a new door sensor, and control panel. What else can it be?
    Scholar:
  • 91 Answers
Hi dear.According to your explanation,MAIN PWB ASSEMBLY is faulty.Not the door lock or control panel.However you can try this & see if it's works.I hope that helps.Thanks. Does the spring of Latch Hook actuate?If No:Replace door assembly
Is there clicking sound once or twice when the
START/PAUSE button is pressed to start the cycle? If No:Check the DOOR SWITCH
ASSEMBLY Connector and
MAIN PWB ASSEMBLY
(Red 4 pin and white 4 pin
connector (1)).
Is DOOR SWITCH ASSEMBLY broken?If Yes:Replace the DOOR
SWITCH ASSEMBLY
Posted on Sep 01, 2010
  • theofour Sep 01, 2010
    Actually I apologize we did replace main pwb assembly, not the problem. It clicks twice says the door is locked, but it is not. We have also replace the door switch assembly. Someone else suggested it could be a failed pressure switch. ?? 16.00 part so I am going to try it. It almost seems to be out of sync or something...I think it operates as usual until it cannot lock the door, so it stops.
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
My LG machine shows dE as soon as I start it. The lid is closed. What to do?
Check the owners handbook if you have it. If not go online to the main LG website find manuals and download one. Have your model and serial number ready, these are on a sticker on the back.
Mar 30, 2015 | LG Washing Machines
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
De is displayed when i turn machine on
You may have a door latch problem and it will need to be replaced.
Mar 12, 2008 | LG WM-1480FHD Front Load Washer
Code de
de is 'door error'. I just fixed this with a new door catch/switch (called a door overlock). Theres a bi-metal strip in there that makes the contacts as well as keeping the door locked closed when its working and it looks like this was the culprit as I was able to open the door even when the machine was filling. The de was intermittant, if you continued to open and close the door it would start eventually - if it does this try changing the switch, cost about £30.
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Can't unlock door!
Press "end of cycle", & wait for click or 2 minutes before trying the door. Would be good to get the exit hose off the standpipe to let the excess water flow out at floor level. Do not force the door.
Jan 23, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
383 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
