Powercord prongs are broken. is there a way to have it hardwired by an electricain? the wires have a shield around them.
  • 43,501 Answers
Hardwiring the unit is easy for an electrician...the shield is no problem...it also would be very easy to install a new plug on that cord also...
heatman101
Posted on Aug 21, 2010
I need wiring diagram for Amana AKT3650E. I have 220VAC supply without a neutral. Electricain says the warning lights need 115VAC. How it that achieved?
So the manual:
http://media.datatail.com/docs/specs/164433_en.pdf
says the power requirements are 120/240 VAC 3 wire single phase.
Almost all wiring includes a ground wire, so saying 3 wire also says it additionally has a ground wire. However, many oven outlets were wired using the neutral as the ground (now considered illegal - especially for new installations) - so they had a 3 prong plug.
Metering from any 2 holes (at a time) in the receptacle should reveal 240 V (across the similar slots) and 120 V and 120 V (from outside slots to middle slot).
have a look at this thread
Installing 3 prong outlet for new range Family Handyman DIY Home Forum
Feb 24, 2015 | Amana Kitchen Ranges
How can I turn on the headlights when the headlight switch is broken in a 1997 cadillac seville sls
You could hardwire them under the hood and add a temporary switch. Will require removing the connectors and making a new harness with connectors and a ground. may be able to run the ground wire into the car to turn them on and off. You will need to place a fuse in line as the original fuses will not be connected. Simple usually three prongs on each bulb. one for ground, one for regular beams and one for high beams. Running these wires will be easy to do but finding out which prong on the bulb is which will require me to actually see it.
Jul 18, 2014 | Cars & Trucks
I have a Whirlpool ARC5753/2 fridge/freezer. I had to replace the power lead as it got cut, but I can't remember which terminals to connect the 3 wires from the 3-prong plug to. The compressor start relay...
Please, don't mess around with power cables. If you connect it the wrong way around the outside metal parts will carry dangerous voltages and can kill you.
in Europe the brown and blue are supposed to carry the voltage and a green/yellow wire is supposed the shield / earth.
our engineers don't have a diploma because they are better skilled with a screwdriver, but because they handle equipment that can be lethal when not handled correct.
Jun 04, 2014 | Refrigerators
How do i use a 3 prong plug for frigidaire dishwasher instead of hardwiring
Hello - I understand that you want to know if you can use a 3 prong plug instead of hardwiring the dishwasher, however may you please provide me the model number so I can assist you better in pinpointing you the information?
Nov 21, 2012 | Frigidaire Dishwashers
There is noise interference from the microphone points when i switch on and off the lamps. i have a AV rack.
Is this a home recording setup?
Often home wiring is not of an adequate standard for quality recording. The problem then lies in 'noisy' wiring - cables in the wall that are not well shielded from each other.
Two possible solutions:
First, if the plug from your recording equipment is 3-prong, try using a 3-prong to 2-prong adapter for it. This would eliminate noise from the grounding wire.
Second, consider purchasing a "Power Conditioner". Prices can range from US$50 to several hundred dollars.
Mar 14, 2011 | Televison & Video
Hardwiring shop lights to an existing light. I have a flourescent shop light with a two prong plug on the end of it that I would like to hardwire into another light fixture in my garage. How do I know...
If the prongs on the plug are of different sizes, it's a polarized plug and the smaller one is the hot wire, which should be connected to the black wire in the existing fixture. If the prongs are not of different sizes, then the fluorescent fixture doesn't require a polarized plug, and either wire will do.
Nov 29, 2010 | Hammering
I misplaced my powercord for my lesmark X7170 where can I purchase one from
Hi, try to check first if your power cord should be a 3-prong cord or a 2-prong cord by checking the power supply behind the printer where it should be plugged in. Then, check at your nearest electrical/electronics shops around your area if it's available. Otherwise, try to call Lexmark and check if they can assist you with that. I hope I could help you more with that. Good luck!
Mar 18, 2010 | Lexmark X7170 All-In-One InkJet Printer
On the of the prongs in the XLR connection got pushed in when someone plugged it in wrong. How can I pull it out?
you can't. The best thing to do is to cut the cable at the head, go to radioshack/online electronics source to pick up the replacement head (shield, prongs, and outer-casing), and re-solder. XLR cable are real easy to build because there are only 3 wires to connect to 3 prongs. A little solder will go a long way. The prongs are numbered, and the cables go as such: red-2, black-3, naked-1. Make sure you feed the bottom shield over the cable before you expose the wires to make it easier. Once your soldering is done, slide the outer metal casing over the prong unit, and screw in the bottom shield to tighten. Really that simple. :D
Mar 12, 2010 | Shure SM58 Professional Microphone
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
