Question about Kenmore Refrigerators
Icemaker leaks - constamtly - Kenmore Refrigerators
    Genius:
  • 1,478 Answers
A small leak in the ice maker can be due to a crumpled water line, while a substantially large amount of leakage could be due to a major failure of any part. In either case, check whether the refrigerator and ice maker are leveled or not. If you notice any component is malfunctioning, get it replaced immediately.
Take care.
Posted on Aug 21, 2010
Why does water drop before ice is made?
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Mar 28, 2016 | Refrigerators
Icemaker leaking despite replacement
is the ice maker actually leaking or do you have a crack in the ice bin allowing it to leak from cubes?
Aug 27, 2015 | Refrigerators
Serial # k15004707 model # mf12665xew3 french doors ice maker in upper left corner. After the ice maker fills with water it drips off the front side.
May 05, 2015 | Maytag Refrigerators
How to fix a kenmore ice maker leaking water
Feb 20, 2015 | Kenmore Refrigerators
Ice maker leaking water
Jul 14, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Sony dcr-dvd703e handycam constamtly error : "disc error - remove disc c:13:02. help please
Have you try clean the optic using lens cleaner. If you never do this for long time, you can try it now before retry your disc.
Aug 27, 2011 | Cameras
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Monogram zdis15 icemaker - leaking
That is the solenoid valve that controls water going into your icemaker. If it's leaking on the icemaker side, then that amount of water isn't making its way into the tray and the ice is "thin".
You'll find two hoses connected - one from the house water supply (that one would be leaking all the time) and one to the icemaker that leaks only when the valve opens during a fill cycle. Check that one to see if it may just be loose, or perhaps a crack has developed in the tubing. Tricky part is it will only leak when the valve is operating for a few seconds during a fill cycle. If you have some electrical know-how, you can power the valve manually to see if you can spot the leak. If not, and you can't find anything loose or broken you may need a service tech.
Mar 04, 2018 | GE Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
