Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
Buzzing noise! when the
When ending the wasing cycle and try to empty the bowl. I hear a buzzing noise and noting appen... the pump seen's ok.... buzzing noise seem's to come from where the hot and cold water come in.
Thank you to help me out with this!!
    Problem Solver:
  • 12 Answers
Sounds like you have a problem with the water solenoids (the electronic controlled water valves) the buzzing is an indication that it is trying to open or close and unable to do so. an electric current creates a magnetic field pulling a spring loaded valve sealed inside a tube allowing water to pass. it starts buzzing when it can't pull the valve all the way and just vibrates.
Posted on May 03, 2008
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
A buzzing noise everyonce in a while when clother
This could be simply your end of cycle signal that goes off. but if your hearing this while your clothes are drying, depending on where your hearing this buzzing it could be possibly something stuck inside your blower fan and is now rubbing up against it. this usually can be seen once the front panel is removed. It could also be your timer depending on where your hearing it from. a lot of older units will have a noisy timer motor, even though the timer itself will be okay. hope this helps.
Thanks
Oct 14, 2009 | Kenmore Dryers
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Loud Buzzing noise
Sounds like something may have got past your filter and is touching the main pump impeller eg piece of broken glass or piece of plastic.I,ve even seen a spoon touching the impeller. You may have to take the bottom off the machine and remove the pump if you can,t see anything under the filter,Hope this helps. Regards Stefan.
Jul 08, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Master door switch? or something else? buzzes when i press lock
ok ur door lock switch isnt going out,,however ur drivers front door lock actuator is going or is already bad...have that replaced..also as far as the end noise buzz u hear , that may be ur a.b.s modulator and accumulator cycleing on and off..it may be empty and or leaking..have the a.b.s modulator and accumulator checked at the dealer..its an expensive fix... ur modulator unit in in the front left or right of the vehicle depending if u have a v6 or 4 cyl. its a square unit with a rectangular brake fluid resevroir and a long tubular cylinder (acummulator)... also identify it by the orange connectors...and the brakelines going to it...common symptom with those accords....they leak alot especially if with high mileage..
Apr 09, 2009 | 1996 Honda Accord
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
301 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Chris Hall
Chris Hall
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
