Question about LG 23LX1RV 23 in. TV/DVD Combo
After watching a DVD, I now get the same show on every TV channel. It has to be the TV because I was able to get different shows with another TV hooked up to that same cable feed. The cable provider just left and said the feed was fine. I've set the Tv/AV and Multimedia buttons to TV and nothing happens. I've also done the EZ Scan and it didn't pick up the majority of the channels.
  • 10,594 Answers
It sounds Tuner become defective in your tv and unable to receive different frequencies of tv channels.
Local tv repair shop will help you to replace tuner on main board
Thanks.
Posted on Aug 21, 2010
New dvd player wont play when I change channel to av. All plugs in correctly. I have an indoor antenna but get every channel. What is wrong?
Try a different channel on your TV Some times it may be AV1 or AV2 on the TV that you have to connect to. The DVD should also show a "start up" screen on the TV to show you that it has connected properly.
Apr 19, 2015 | Televison & Video
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Sony rmt-d224a manual
Much better to get one of those set-top boxes, connecting it to a spare scart socket on the back of your recorder. This way you can watch a different channel on the TV and still record the TV show you want to watch.
Feb 04, 2014 | Sony RMT-D224A
What channel do you watch a vcr/dvd on.
It depends on the way you have the combo set up, your instruction manual shows you different ways of doing this, but to answer the question it would be channel 3 or 4 if you are using the RF out ot OUT to TV connector in the back of your combo. You can also view tape and disc playback if you set the TV for VID1 or VID2 if you are using the rca dubbing cables(yellow-red-white).I hope this helps!
Jan 05, 2010 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
Can i record from tv to dvd
yes
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
Feb 13, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Changing Channels
Unfortunately, no. The tuner in your DVD recorder works differently than how your satellite receiver works. You *must* use the satellite receiver to select the active channel, and then send that channel to one of the inputs on your recorder. You can then record that channel. Unless your satellite receiver is has "dual tuners" in it, you are stuck watching the same channel that the DVD recorder is recording. If your goal is primarily time-shifting of shows (as opposed to archiving shows forever to DVD), you might consider getting a different satellite receiver with a built-in DVR (hard disk recorder). These allow you to mark shows in advance, have them recorded to the hard drive, and then you can watch them whenever you want, skipping all the commercials. You also get the ability to pause and rewind live TV.
Apr 14, 2007 | Panasonic DMR-E50 DVD Recorder
LG 23LX1RV 23 in. TV/DVD Combo Logo
73 people viewed this question
Computer Repairing
Computer Repairing
