Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
I put the wrong soap.. now continuos beep and progam locked on rinse
  • Fisher and P... Master
  • 3,247 Answers
Most likely the flood switch has triggered due to the foam.
Turn of the power at the mains and wait an hour or so and turn back on.
If the beeping continues then you will have to dry the flood switch.
This means turn the power off again. Take the bottom drawer out from the rails. Get a towel and dry the base of the housing from inside. Use a hair dryer to dry out the centre part of the base where the flood switch is located.
Put everything back and turn on the power. This should get rid of the problem.
Please rate the solution if it was helpful or else post a comment and I will try to help out further.
Posted on Aug 22, 2010
Error code sd
sd means suds, for either the wrong soap was added or just had too much soap. Rinse out washer, you can use a small cap full of oil (like the oil cap) to deactivate the soap. Then rinse out washer again, this should fix or correct this issue.
Good Luck
Aug 04, 2014 | Whirlpool Washing Machines
When I hold start button, longer beeping noise won't start
might be your lid lock are door lock switch is bad if you have your manual tell how to put washer in program mode then it should give you a errcode show you what wrong with your washer ok
Oct 21, 2017 | Whirlpool duet Washing Machines
There are soapsuds in the bottom of the dishwasher when the cycle is done
This sounds like the dishwasher got the wrong type of soap. It is a real problem to get the wrong soap rinsed out..follow the directions given by the repairman..it may take 5 or 6 cycles... The jet dry is just an extra in this issue...it will be okay when the soap is fully rinsed out.
Feb 02, 2013 | KitchenAid Architect? II K SERIES KUDK03IT...
What is the purpose of the lock and refill by the location where you put the soap
That is the rinse aid dispenser.
Turn the knob to refill and pull it off. Pour rinse aid into the area below the cap you took off, once full put the cap back on and turn to lock.
Rinse aid is critical for proper drying and rinsing.
Jun 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Added the wrong type of dishwashing liquid to my dish drawer!
start, fill and then select rinse only,,,as many times as it takes to flush out the soap...
Jun 11, 2010 | Fisher and Paykel 23 in. DD603H SS...
Washer stopped in rinse cycle.
Sounds like a control or door lock problem. Try resetting you ccu ( computer control) by unplugging the unit for 30 minutes first. If this does not work then you probably have a bad door latch or bad ccu. You should have a technician do this repair. The wrong soap will not cause this problem, although it can eventually cause other problems. Good Luck, Appliance Specialists
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The soap compartment is not locking shut
this is a spring loaded function.if it does not lock any more you will need to replace the unit,otherwise just use the unit as is it will still wash.
Jul 16, 2009 | Dishwashers
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
Washer flashing F then went to SUD
Drop the drain hose so that it is lower than the drain and let all the water run out of the machine. Open the door and remove all washing. Let machine go through rinse cycle with some milk mixed in with the water, (pour the milk into the soap container, about one cup) and make sure there are no soap suds left in the machine. Check that you are using washing powder which is recommended for front loaders.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
85 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
