Question about Samsung PCL5415R TV
Samsung 52 in. projection TV
The model is PCL541R
The color is saturated with red and green with bright blurry whites. I bought it from a friend and it worked fine, once I got it home this is what I got.
Also for some reason the remoted won't work, I've changed the batteries.
  • 1 more comment
  • SgtR235 May 06, 2008
    I will certainly try to get a pic and send to you. Any help you can provide would be most appreciated, thanks.
  • smashamole Jun 10, 2008
    i have same problem. is it the convergence ic?
  • tuggs85 Nov 19, 2008
    I am having the same problem i think... the colors seem to be slightly off and all the white seems to be really bright and blurry. Any solutions for this yet?
  • Samsung Master
  • 8,617 Answers
Is there any way that you can take a pic of what the screen looks like and post it here or send it to me at slinteriors@yahoo.com I could make a more accurate assesment if you can.
Posted on May 03, 2008
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Samsung projection tv
This is most likely a convergence problem. Does the picture look like 3D? If so, please confirm that the model is PCL541R and I'll rpovide additional details and instructions.
Dan
Sep 24, 2008 | Samsung PCL541R 54" Rear Projection...
Samsung PCL541R conversion alignment
move the blue and the green to the red till they turn white.
good luck
please mark the post with a fixya!
Dec 15, 2007 | Samsung PCL541R 54" Rear Projection...
Color going
your colour guns (that's what they call the light tubes that produce the 3 main colours, red/green/blue) need to be fixed. One or two of your guns need to have the liquid that protects the lens flushed out. I had the same thing and the repair man came in took the unit apart and removed one of my light guns (blue one) and showed me the dis-coloured liquid. He drained the liquid and added new clear liquid which protects the heating of the gun and everything was perfect again.
Oct 17, 2007 | Samsung PCL541R 54" Rear Projection...
Televison & Video Logo
196 people viewed this question
Henry  Thomas
Henry Thomas
