Question about Samsung 906BW LCD Monitor
Screen flickered and finally went black - Samsung 906BW LCD Monitor
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.badcaps.net
Posted on Aug 23, 2010
What could cause my VIDEO CARD to fail?
This could be a simple failure of your video card. However, I had this happen and found out it was a heat sink that had come loose from my motherboard. (Heat sinks are the aluminum blocks, with fins, on top of CPUs on your motherboard, or on advanced graphic cards.)
Mar 17, 2014 | ATI Computers & Internet
My ibm laptop, was working great until this morning, the screen started to flicker, then the icons started to dim and completely disappear and then the screen went to a coloured test pattern and finally...
Check the power supply.Hope the notebook receives power from the battery or the Ac adapter.We need to ensure there is no issue with the power supply.boot the notebook to the safe mode.If it boots to the safemode perform a system restore.In case the notebook does not boot to the BIOS,connect to an external monitor.If we still do not get a display,its the video card
Mar 02, 2010 | IBM ThinkPad T40 2373 Notebook
Noticed screen flickering occasionally the last
Screen bulb burning out, bad inverter, or LCD wires crimped or exposed and touching each other and shorting out.  Have IT open this puppy up and look into it or you can do it if you got the tools and your handy. You can get a new screen on e-bay for around $150
Oct 30, 2009 | Sony PCGK37 Notebook
Hitachi 52 in. Plasma
I think you may have dry solder joints on the line output stage. If the solder joints are checked and found to be good then suspect a component on the line output stage or the line output transformer itself. If you can check these faults for yourself start with the solder joints otherwise find a competant technician. Hope this helps.
Oct 05, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor flickered and then... smoke!
Hi Konsuma, You can open the monitor case and look to see what is damaged and order a new circuit board if needed. Check with www.lcdrepair.net parts and/or Repair.
Oct 09, 2007 | HP Pavilion F1703 17" LCD Monitor
My laptop screen is flickering
That could be ths connector that connect the LCD to the Motherboard in the laptop. Ive seen something similiar wherein i took down the screen, cleaned up the connectors and it worked like new...... for a few weeks then it went back and started he flickering again. We finally fixed the problem by replacing the screen. Apparently the connector behind the screen was giving trouble. Have someone check the cable from your LCD to the board but I think you might need to fix the connector or replace the LCD screen. Regards, babb
Apr 19, 2007 | Evesham Voyager 5800 Notebook
Samsung 906BW LCD Monitor Logo
248 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
