Question about Bosch Dishwashers
Model SHE68P02UC/60 There does not appear to be a drying heating element in this dishwasher or did we miss connecting something up during the installation? Unsatisfactory drying on both "normal" cycle and "auto wash" cycle.Drying agent is in machine. What is "condensation drying"? Is this just blowing cool air through the machine and out through the vent? If so it is unsat. How to get the machine to actually DRY the dishes? I'm going to be very disappointed and out over $1,000.00 if drying is not possible and I have to junk a brand new machine.
  • Bosch Master
  • 3,247 Answers
I am assuming you have the dishwasher connected to the hot water tap which can give water at about 40deg c (120deg F).
The dishwasher uses steam from the water (after heating it further). So if the inlet water temperature is not correct then it will struggle a bit for both washing and drying.
See instructions for installation and user guide on this website.
Hope this helps.
Posted on Aug 22, 2010
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
The dishwasher is not heating up during washing or drying - it appears the the heating element has broken - is it easy to repair
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Dishwashers
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Hotpoint Dishwashers
Heated dry cycle does not work.
IS ELEMENT HOT DURING DRY CYCLE, DROP SOME WATER ON IT. CHECK FOR VOLTAGE TO ELEMENT DURING DRY CYCLE, IF VOLTAGE AND ELEMENT DOESN'T HEAT THEN IT IS OPEN/DEFECTIVE. IN THE CONTROLS OTHERWISE.
Mar 10, 2010 | Whirlpool Dishwashers
Dishwasher does not dry dishes. dishes are not hot at end of cycle. seems like heating element is not heating
Connect a volt meter one lead at each terminal of the heater. Read the voltage when it is in the drying cycle. If you get about line voltage the heating element is bad. If you get no or very little voltage it is the timing unit. If you are uncomfortable measuring voltage remove one of the wires from the heating element, after unplugging it, then connect a ohm meter across the heater. If it reads above about 50 ohms it is bad, if not probably the timer. Of course you could always connect a light bulb across the two heater terminals and if it lights during the drying cycle the heater is bad.
Good Luck,
Gil
Mar 01, 2010 | Dishwashers
Not drying dishes
Without knowing the make and model of your dishwasher, the most probable causes of no drying is:
1.) RinseAid being empty or not dispensing (as in you never seem to have to refill the dispenser.)
2.) The Heating element has failed. But if it has failed, you would also have foggy, film on your glassware.
3.) The timer is failing to turn on the heating element during the (at least) the heating element during drying cycle.
Good Luck!
Apr 06, 2009 | Dishwashers
Does Not Dry Dishes
Withe the model and serial number it appears that this dishwasher is less than 2 years old.
Your symptoms point to a failed heating element. That is kind of surprising because this dishwasher ~should~ report an error code if the thermistor does not detect the raising temperature from the heating element.
The LG LDS and LDF models do NOT turn on the heating element in the drying cycle. It turns it on during the final rinse and the dishes dry as the built in fan runs.
So, I suspect the drying fan and related gear is inside the door panel. Do a load of dishes and listen for the final rinse to drain. Then, listen really closely near the top of the door for the quiet sound of a fan _and_ place your hand underneath the left hand side of the closed door for warm air blowing straight down.
If you do not hear./feel what I discribed , the drying system has failed. OH, and if you have any water leaking from the door (right where the warm air is supposed to come out, contact LG service folks and firmly request that they replace the drying parts with a retrofit kit.
Please review this and tell me what works and what questions you still have.
Good Luck and please keep me posted! OK?
Mar 24, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | Dishwashers
Dishwashers Logo
48 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
