I have a Kenmore 90 plus Washer and it is leaking at the bottom out of a white piece that is fastened to the motor and the water exhaust tubes are attached to it. How do i remove that part. I have tried pulling the part off with no success. Any ideas
  • 3 more comments
  • Bob Henry Aug 21, 2010
    It came off and i put the part back but now it does not recognize when the the washer has enough water and overflows. So it never goes into the agitate cycle. Thanks for your help.
  • Bob Henry Aug 22, 2010
    Thanks for the response. It is definitely overflowing over the top. The water never shuts off. Not sure what you mean about the control panel.
    Thanks Again
    That did it! Thanks. One last question. My wife has just about had it with me fixing this old washer and dryer. I would like to buy a top of the line used washer and dryer. Do you have any suggestions. I looked at the Maytag Neptune but the reviews were terrible. I thought if anyone knows you would know.
    Thanks for all your help, i will give you the top rating.
    That did it! Thanks. One last question. My wife is finished with me fixing that old washer and dryer. Do you have any recommendations on a top of the line used Washer and Dryer set. I need a gas dryer. I looked at the Maytag Neptune but the reviews were terrible.
    Thanks for all your help i will give you a top rating.
  • Bob Henry Aug 23, 2010
    Macmarkus's help was outstanding he went way over and above what i expected.
  • Washing Mach... Master
  • 2,605 Answers
welcome to Fixya.
The pump does indeed pull off...once the 2 metal brackets are removed. It an sometimes get stuck on the motor shaft and require a little more "persuasion" to come off.
The part number will be # 3363394.
Here`s a helpful link that will show you a complete "how to". It will also show you how to do the drive coupler if ever needed for future use. The machine used in the demonstartion is a Whirlpool, that is the manufacturer of your Kenmore.
http://www.youtube.com/watch?v=U-Px0vTohhg&feature=related
Let me know how you make out or if you require further assistance.
Thank`s for choosing FixYa today and good luck.
macmarkus :)
Posted on Aug 21, 2010
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Aug 21, 2010
    Hi, glad to hear you where somewhat successful at least.
    As for the leak/overfill. Is it indeed flowing over the top or spewing out the side where the pressure hose connects to the air dome ? If so out the side, maybe that little clear pressure hose has come off the dome or if overflows the top, the other end where it connects to the switch in the control panel. If either is the case it will overfill or leak out the side, depending on what end is disconnected.
    It may also be a case of lint blocking that small clear hose or the dome entrance inside the outer drum...it is actually very common.
    Let me know what you find and we can go forward from here...if need be.
    Good luck again.
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald Aug 22, 2010
    Hi again,
    I need to address your first statment off the top..."The water never shuts off". You mean while the unit is powered ON right ? Not all the time even if unplugged ? Because if it fills even when OFF you have a stuck fill valve open. If only when powered, then it is related to what I alluded to before.
    Let me know.
    Now the second part of your statment..."Not sure what you mean about the control panel".
    On the top panel where the timer is located, is the control panel. It is typically held in place by a screw on either side and then flips up & back when un-fastened.
    Did you have the cabinet off when doing the pump change, or did you do that from the bottom ?
    If not through the cabinet removal method, here`s how...( it also refer`s to possible pinched hose...the pressure hose I alluded to previously...scenario which will cause overfill )
    http://www.youtube.com/watch?v=6XIsK3W_Q...
    You can also go back to the previous post and click on the link I sent and that particular series of video`s is pretty helpful, even if at first somewhat annoying.
    Let me know how it goes.
    macmarkus :)
  • Mark MacDonald
    Glad to hear you are up and running again. Good job , you just saved yourself in the range of $200 likely !
    As for your last question, "Do you have any recommendations on a top of the line used Washer and Dryer set"
    That is a matter of opinion, but since you're asking mine...I'd say status quo.
    What I mean is this. There have been lot's of advances or at least perceived advancment's ( opinion again ) in modern laundry system's, most of them for environmental reasons. While I'm all for thing's which help preserve our precious resources, I am also a money conscious consumer too, hence my desire to help folks fix things as opposed to dumping them every 5-10 yrs.
    That being said, if you are in the catagory of "give me the best money can buy" I'd say hands down Miele laundry system's. If you are more of the mind as I am...( thanks dad, ha ha ! I like things I can at least begin to understand how to fix ) and a limited budget ( as I am ) I would go with the tried and true top load Whirlpool made machines you presently have.
    They also make a very dependable machine in my opinion and dollar for dollar the best...and by and large still built this in the U.S.
    You can opt for a Gas dryer to match almost any of their washer's, as I would strongly recommend as well.
    I will also take a moment to mention to you I wouldn't suggest the Maytag Neptune machines you referred to...unfortunately. Maytag had a reputation of building quality products for nearly a 100 yrs.( starting with farm machinery believe it or not ) until they built the Neptune.
    The problem with the Neptune is not so much it's mechanical engineering, I think they are excellent in that regard, it lye's within the control assemblies. Do some searching around on this site ( FixYa )as well as "google" and you'll see many testimonies to what I'm referring to.
    In closing if you can find a good refurb or second hand topload washer & dryer built by Whirlpool ( Kitchen-Aid, Kenmore, Roper, Estate, Whirlpool, Inglis...and that's just the ones which come to mind immediately ) that is the direction I would be most comfortable in steering you these days, not to take anything away from the modern energy efficient front-load machines such as Meile, Bosch, Asko, AEG, Samsung, LG or even Whirlpool frontloaders, it's just my opinion.
    I hope you found this helpful and will take a moment to rate my assistance and leave a testimony should you think it's warranted.
    Good luck going forward once again.
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald Aug 23, 2010
    Hi reh144,
    I don't know if you received my post in reply to your last inquiry ( what washer/dryer I would suggest ) but if your machine is now fixed I'd just like a follow-up from your end. All that is needed is for you to select the solution from me "accepted" and the post will come down from the "still unsolved" list.
    Let me know of course if you have anything else or didn't see my recommendation response.
    Regards,
    Macmarkus :)
Water is leaking during the wash cycle. Nothing shut in the door. Been happening with the fuller loads.
try wiping or cleaning off the bottom part of the door,i've seen pieces of hair on the door and water leaks down the pieces of hair through the door,if that's clean then check for a hole in the rubber boot seal,most likely there's a hole in it
Feb 21, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How remove Kenmore frontload basket from rear shell?
this is a big job and prob spendy if not under a warranty......
the outer tubs are connected by metal fasteners which need to be removed by a flat screwdiver mark the old fron outer basket with a marker so u can replace those clips in the same manner..........to get acess to the tubs turn power off and remove top, remove back panel, remove front as well console bottom panel etc,,, disconnect all componets,bellows gasket ,connection wires, tubes, remove motor, undo bottom pump tube, remove belt and remove back bolt holding on pulley, get two people and remove tub out front when completed disasseblying all necessary pieces.. once tub out then remove those metal fasteners and set aside front tube reinstall onto new rear/inner rear tubs... hope this helps i might have forget some things actually i know i did this is a complicated process hope this helps let me know
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
Water leaking out of bottom of washer
There are only a few issues that I usually see with kenmore direct drive washers pertaining to leaks. To check everything you can do it from the bottom. Pull the unit out and lean it back against the wall. Make sure that you have enough slack on fill hoses and drain hose. These are the list of things to check.
1) the pump mounted on the front of the motor. Check the backside and see if its worn through and it could also leak from the center where it goes on the motor shaft.
2) The hoses that connect to the pump.
3) There is a spring that hooks into the back of the tub which will sometimes rust out causing the tub to lean forward during fill and the water splashes off the backguard. (if the spring rusted out you can redrill a hold in the base of the washer and reconnect it)
4) The pressure switch fill tube got ripped out of place this is the clear tube located on the side of the tub. (this would be typical to see if when the washer is in spin and you open the lid it comes to a hard halt). In which case you can tip the machine back and carefully spray some wd40 or white lithium grease into the brake. (be careful not to get any on the clutch which is the silver disk on top of the motor).
Let me know if this helps.
Jan 22, 2010 | Kenmore Washing Machines
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Kenmore 90 series mod.# 110.28912791
OK The Kenmore 90 series mod.# 110.28912791 is not hard to work on. The problem on the washer was no agitation or spin.First I took the agitater out of the tub,and put them aside. Then I tilted the washer to get to the bottom of the washer. Inbetween the motor and I gueuss pump there are three pieces that need to be replaced called (motor coupler). I disconnected ac cord from wall outlet, the cold and hot water hoses. I disconnected the wires at the motor one piece and one two wire connection pluss move a small canister with two wires out of the way. Removed three bolts bottom of pump pulled pump and motor out, you have to turn back and forth a little and the whole assembly comes out. there are two screws that hold two clips at side of motor and motor come off easy. You will notice there is a black rubber disc with a plastic white three prong piece on each side. (Remove those pieces install same way ( you need to use something to hit the center of the plastic till it sets in, install black rubber piece six wholes three prongs on one side. Install second white pronged piece on the pump side and also hit center to set. Place pump over motor looking to (make sure) the top three prongs go inside three holes left in the black rubber piece. Once you line and they go inside line the motor to where the for rubber legs sat before put clips back on install the two screws, install shaft back in moving the motor side to side install the three bolts, hook wires plugs under the motor put canister with two wires back hook the two hoses back next to motor, stand washer back up, install agitater back, hook hot and cold hoses back plug back in and test. parts at sears (one hours time start to finish taking your time) keep track of all parts. Make diagram if you need to believe me it was easy and washer works great now. By the way when I took the parts off they did not look broken but were bad because now I have a working washing mashine. ( Good Luck, Wyatt Earp )
Feb 02, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
