Question about Arris Surfboard SBG900 Modem Cable Modem Gateway 80211BG Wireless Adapter
Where is the wps switch on the modem gateway wireless sbg900
How do i turn wifi off surboard sbg6580
log in to the modem as if you were going to change the wireless password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
try these
SBG900 Default IP:
192.168.0.1
SBG900 Default Password:
motorola
SBG900 Default Username:
admin
Nov 19, 2013 | Arris SURFboard SBG900 Wireless Router...
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
I FORGOT WHERE TO FIND THE PASSWORD FOR MY WIRELESS TO HOOKM UP MY PS3
you must browse your router and go to the security section under wireless configuration. see page 87 of (http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG900-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SBG900_User_Guide.pdf) for screen shots of where to look.
and remeber a PS3 need to have broadcast of ssid turned on for the intial setup.
GL
hope this helps
Don't forget to vote for me
TY
Jammer
May 27, 2011 | Arris SURFboard SBG900 Wireless Router...
Is the Motorola SBG900 cable modem gateway a router- that is will it enable file sharing between the computers that share the gateway (one wired, one wireless). If so how is this set up?
you should be able to set up a home network you will have to enable file sharing, if you run through the network setup wizzard in the control pannel it should be fairly straightforward
Jan 21, 2011 | Arris Surfboard SBG900 Modem Cable Modem...
I have the wireless cable modem gateway
Here is the User guide for your modem:
http://www.motorola.com/staticfiles/Consumers/Products/Cable%20Modems%20and%20Gateways/SURFboard%20Wireless%20Cable%20Modem%20Gateways-SBG900/_Documents/Static%20Files/SBG900_User%20Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 29, 2009 | Arris SURFboard SBG900 Wireless Router...
Downloading Problem with Motorola SBG900 Wireless Cable Modem Gateway
Sounds like your laptop is hit with spyware and or viruses. Try starting it in safe mode (F8) and seeing if you still have this problem. If it works in safe mode go to grisoft.com and download the antimalware free trial. Restart in normal mode and install and run the trial version.
Aug 05, 2007 | Arris SBG1000 Wireless Cable Modem Gateway...
Arris Surfboard SBG900 Modem Cable Modem Gateway 80211BG Wireless Adapter Logo
488 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
