Question about Danby DDR556RH Dehumidifier
My Danby Silhouette DDR556RH dehumidifier is less than 2 years old (out of warranty) and is no longer drawing out the humidity. First, the hose connection to the sump pump stopped working (I have cleaned the filter)and now that the water just goes to the bucket, there is hardly any water in the bucket after 2 days. The humidity is over 65% in the basement. Up until now it worked just fine. Any ideas? When I called the support number, they gave me a repair option but said it will likely cost as much to fix it as to replace it.
Take the back off with a screw driver and you will find a plastic tube that connects the drainage pan to the water outlet on the back. It is probably plugged. Clean it, the drainage pan and the surface of the conddensor (coil). This will help. Keep your filter clean and blow up the drain hole after removing the hose every now and then to keep it flowing freely.
Bob
Posted on Nov 26, 2010
  • Danby Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 29, 2010
Ddr600r
Press the "power" button and then set the humidity level to about 50%
May 11, 2014 | Danby DDR600R Silhouette Dehumidifier
I have a Danby Silhouette and the fan works but the dehumidifier doesnt.
Bryan, it may imply be a case of the humidity extraction level being set to high. Lower the level to 35% and see what happens. As far as the fan running is concerned. Most dehumidifiers are designed for the fan to run, even if the compressor doesn't turn ON. It's designed to keep the air circulating and if the humidity rises above the setting you have it on, the humidity sensor will pick up this change and turn the compressor ON.
Also, remove the air intake filter to see if it's clogged and needs cleaning. Maintain at least a minimum of 12" of free air space all around the dehumidifier. Poor air circulation will prevent the unit from working properly. As will, to low an ambient air tempeature. Most unit struggle to work at temperature between 40 & 60 degrees F.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 04, 2011 | Danby DDR451 Dehumidifier
I just bought a Danby Dehumidifier model: DDR6009REE The fan runs constantly even when the humidity setting is reached and the compressor is off. has anyone patched the power for the fan by putting...
All new generation dehumidifiers are designed to have the fans run all the time and the compressor comes on when the relitive humidity rises above the setting that you have chosen. I spoke with the company and asked them why this is so, and they told me that it is more energy efficient to have the machine on all the time so that when the compressor kicks in there is a small draw on electricity.
Apparently when the old dehumidifiers came on it was the compressor that turned on immediately, and the fan, and this caused a very high current draw. The new design has the fan on all the time and this helps to circulate the air evenly around the area being dehumidified - thus more efficient overall coverage.
I understood their explanation, but still do not like this new method of operation.
Jun 26, 2010 | Danby DDR6009REE Dehumidifier
Hi, My Silhouette 63pint dehumidifier does not ...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 21, 2010 | Danby DDR600R Silhouette Dehumidifier
My dehumidifier is frozen solid
Unplug it ... let it defrost.
Set it to a higher % humidity and make sure the fan is on its fastest speed. If you can set it not run continually (a selection option), do that. Also, set a small fan close by to move more air around the machine. If you have the option, put a hose on the collection device to drain to a sewer.
As your space starts to dry out, set the humidity setting to a lower number. This may take a week or more.
I believe perfect humidity is slightly above 50% - no need to try to get to 40% except in unusual circumstances. If that is the case, get a second device. Or, if your space is large, you may want to add a second device.
I hope this info helps you and your problem is solved.
thanks for using Fixya.com
a
Oct 25, 2009 | Danby DDR556RH Dehumidifier
Unit is repeatedly freezing up
Almost all dehumidifiers now have automatic defrost, but if you are seeing frost is just one small area, it means there is a refrigerant leak. Check your warranty to see if the sealed system is covered longer than one year. Generally, if it is, most manufacturers will replace the unit (rather than repair it, as the repair is rather expensive compared to the cost of a new unit). If you do not have any sealed system warranty coverage left on it, don't fix it. Buy a new dehumidifier.
May 20, 2009 | Whirlpool 75-Pint Dehumidifier
Humidifier measuring wrong %
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 2 years old.
Aug 03, 2008 | LG LD65EL Dehumidifier
Humidty reading remains at 84%
Dehumidifiers are generally a very simple appliance, however a humidistat is one of those items a person tends to rely on to provide feedback. You may want to remove the grille area where the humidistat is mounted and inspect for foreign material in the way of the sensor. If nothing foreign is detected then you should replace the humidistat.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 29, 2008 | Danby DDR586R Dehumidifier - 58 Pints...
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Danby DDR556RH Dehumidifier Logo
551 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
Colin Stickland
Colin Stickland
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
