Question about Lexmark X5150 All-In-One InkJet Printer
How does one remove a paper jam. Have lexmark 5485
  • Lexmark Master
  • 17,130 Answers
Open the panel and have access to the roller. if you detach the side motor it will be easier to manually turn the rollers and get the jammed paper out. You can also get the paperr out by carefully turning the gear drive of the motor and get the paper out. Clean the rollers well before the printer is closed.
Test and proceed., Use the correct grade printing paper.
Hope this helps
Posted on Aug 21, 2010
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
There's paper jammed in my lexmark printer. I can't get to it to get it out.
Open the printer cover. You may be able to get a better grip of the paper jam in the cartridge area. Carefully remove the paper jam. Avoid tearing the paper. Any torn pieces left inside can cause future paper jams.
May 30, 2011 | Lexmark X4530 InkJet Printer
LEXMARK X7550 JAMS &MISFEEDS TROUBLESHOOTING
How to clear and avoid paper jams: To clear the paper path: 1 Pull firmly on the paper to remove it. If you cannot reach the paper because it is too far into the printer, lift the scanner unit to open the printer. 2 Pull the paper out. 3 Close the scanner unit. 4 Press check. 5 Reprint any missing pages. To avoid paper jams, do not force paper into the printer.
The Lexmark X7500 Series User's Guide will be able to give you more detailed instructions on how to troubleshoot paper jams and misfeeds on your printer. You can download the user's guide from the Lexmark website at http://bit.ly/mdAcJO and go to page 177.
May 10, 2011 | Lexmark X7550 InkJet Printer
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
Lexmark x342n printer paper jam
Remove the jammed paper by gently pulling it straight out of the MFp
Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service you will need your printer model type and serial number. If you need help locating this information, click here.
May 31, 2009 | Lexmark X342n All-In-One Laser Printer
Lexmark x215 using printer cartridge 18S0090
Continued to open and shut all covers eventually cleared
Jul 10, 2008 | Lexmark Office Equipment & Supplies
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
