Hi, My washing machine(AEG LAVAMAT 54609 AEG ) was working fine. Now we loaded new set of clothes and try to rotate the nob for 30c wash, no indicators are up, if try any settings, no leds glow. First look it seems as if there is no power to the washing machine, if we connect some other instrument to the electric socket, the instrument works. So that means electric socket is working fine! Please help us.
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
  • 3230 Answers
SOURCE: aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Posted on May 06, 2009
Door glass broken on AEG Lavamat washing machine
Remove door from washing machine, there' screws back side to remove and replace new glass very simple indeed.
Apr 09, 2014 | AEG Lavamat 74640 Front Load Washer
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
What does oe mean
Hi
all washing machines irrispective front load or top load washes ,rinses and spins. Then you need to take out the clothes and put it in a seperate dryer.
In all in one the clothes are washed rinsed spin then dried too. Hence saving you the effort and also space for having an additional driyer.
Its the in thing now...
Regards
Berry.
Feb 01, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
I want circuit daigrame for aeg washing machine
I have an AEG öko Lavamat 64600 washing maschine and I need a circuit diagram. Can you help me?
Thanks,
Bridget
Dec 30, 2008 | AEG Lavamat 88840 Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
Jan 12, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
