Question about Ovens
Magtag Stove CRE9400ACW-- -F2- Does anyone know what this code is for. Was going off abut every hour within last 8 hours, now going off every 10 minutes. Thanks1
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F2 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100 ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
My stove keeps beeping and showing F1-8 on the display and telling me to call a tech. What is the problem. This slide in stove is abou 6 years old.
The F1-8 error code means that a button on the touchpad is stuck in and the touchpad needs to be replaced. The computer runs a self check on the oven several times per hour and it thinks a button on the touchpad has malfunctioned. Depending on your exact model the touchpad is a seperate peice or it has been intergrated into the control panel, so if it's seperate only it needs to be replace,if it's intergrated the whole control board needs to be replaced.
Hope this helps ya
Gene
Aug 01, 2011 | Jenn-Air Ovens
Oven gives code E6 F2 on panel
i have you a tech sheet for you accept this soultion and e mail me at b4829@yahoo.com so i can send it to you just reference code f2 e6
May 24, 2008 | Whirlpool GBD277PD Electric Double Oven
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
Oct 09, 2010 | Magic Chef Ovens
We have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Mar 04, 2010 | Ovens
My stove won't unlock
there may be a problem with the door switch try pushing in the door a little bit.also hold the clear off key for 3 to 5 seconds this should allow you to open the door.
Jan 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My step daughter has pushed some buttons on the oven, and now it is locked.....it is a self cleaning Kenmore convection oven......how do I unlock it?
DON'T KNOW YOUR STOVE BE HERE IS AN SIMPLE FIX THAT MIGHT WORK ADVANCE THE TIME ON THE CLOCK 8 HOURS AND SET SEE IF HELPS IF NOT TELL ME MORE
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag Electric Oven Model#CRE9400ACW (approx. 14 yrs old) receiving F2 and F3 codes. What needs to be repaired? Can oven still be used?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}The error codes suggest that you may be having problems withyour oven temperature sensor (that metal tubing sticking out the back of theoven). You should check that there is no physical damage to the sensor or thatthe connectors are still intact. but after 14yrs - i think its the sensor thatneeds to be changed
Try repairclinic.com - item 1364 about $37
Sep 03, 2008 | Maytag Ovens
Double oven will not work sometime
Mobley, F2-E6 code is cancel key drive line open. The tech sheet I have on this recommends reseating the keypad connector. It then states to press cancel. If the error comes back within 60 seconds replace the keypad....Catriver..post back.
Sep 16, 2006 | Whirlpool GBD307PD Electric Double Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
