Question about Garden
I havea simoniz s1700 pressure washer. when i press the on button i get a low hum and then nothing. appears that the motor may be stuck. anyone know how to get a manual or instructions on how to dismantle the washer to get at the motor?
    Problem Solver:
  • 18 Answers
I will check your capacitor if you are not goog with electricity don't mess with it
Posted on Aug 27, 2010
I HAVE A 2600 SIMONIZ GAS PRESSURE WASHER AND I HAVE LOST PRESSURE. CANT FIND THE PROBLEM.
Hi Trevor
You have one of two problems
1. Pressure relief valve is stuck and needs cleaning or replacement
2. Pistons that pressurize the water need new sealing rings or seals
Bud
Sep 28, 2013 | Karcher 2500 PSI Pressure Washer
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
Where is the pressure switch located on a simoniz 1600 electric power washer?
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Sep 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Aug 11, 2009 | Karcher Garden
Electric simoniz runs for a while than cuts off for awhile and st
Hello: Are you using and extension cord? You cannot, it will kill the motor. If this is not the problem it is the unloader valve sticking. This is quite a job to fix but can be done. Let me know.
Jul 01, 2009 | Honda Pressure Washer PSI 3000
Manual needed for Simoniz S1800 Pressure Washer
I contacted the Company in US.
Thank you for keeping in touch.
Jun 21, 2009 | Garden
I have a Simoniz 1900 presure washer and had to take it apart to fix it. I need to know how to put it together again as it has been awhile since I have had a chance to work on it. Can anyone tell me how to...
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
May 17, 2009 | Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
748 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
