Question about GoVideo Go Video DVD/VCR Combo
Go video dvr 4000 dvd stuck..door won't open - GoVideo Go Video DVD/VCR Combo
5 Suggested Answers
  • 1003 Answers
SOURCE: Go Video Unlock Code
check the menu settings or (setup) on the dvr 4000 to see if it has options to enable or disable parental lock or to change region settings to region 1.
also the dvds you made are they +r or -r on what brand dvd record disc on dvd-r this may solve the problem but use a quality brand disc like memorex dvd-r it is compatible with many players and recorders also make sure the disc you made on the recorder were finalized.
Posted on Jan 15, 2008
asnowman
  • 788 Answers
SOURCE: can't record from Cable DVR
Here is a diagram of an option for you to hook up a cable box, to a VCR, then a TV. I took out all the other things and kept it simple. You can always hook up more later. The cable should go straight into the DVR as it is, then hook the yellow A/V cables from the DVR/cable box output to the VCR input then anther set of A/V cables from the VCR out to the AV1 on your television.
You will have to select the A/V input on the Go Video, then you should be able to see a picture. The only drawback on this option. You will have to watch what you record.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 30, 2009
ekmoetweet
  • 124 Answers
SOURCE: The DVD gets stuck inside
Open up the dvd player (first unplug) by loosening screws on side and back take out disk and clean round spindle the disk is sticking too.
Posted on May 11, 2011
bobhifi
  • 635 Answers
SOURCE: Go Video DV 2150 - DVD door won't open at
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Posted on Sep 13, 2011
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Reset dvr 4000
Unplug the dvr from the electrical outlet.
Wait for about 15 minutes.
Plug back in the dvr.
Feb 04, 2012 | GoVideo DVR4000 DVD Player/VCR
How i can see dvr hd716 in ipad
so far, you cannot view the Panasonic WJ-Series Recorder using other browser than Microsoft Internet Explorer. because it use ActiveX Component to view the Video.
you can acess the Web Base interface of the DVR, just input the IP Address of the DVR, set disable pop up blocker for your browser, then it will show.
in some case, other browser than Internet explorer won't show the web correctly.
Sep 15, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
How do i connect to Panasonic Wj-hd716 from my iphone?
Sep 07, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
My pioneer dvdrw dvr 107d door wont open when i press button /have cd stuck inside (worked 5 mins ago) can still view dvd content/ will driver update fix ? please help
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
Can't record from Cable DVR
Apr 30, 2009 | Televison & Video
Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Jan 02, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Door is stuck
I had the same problem with mine. I contacted Hitachi, and the only solution was to send it to the dealer for repair. I live in Las Vegas and the closest dealer is in Carson, California, so I shipped it. It took about 3 weeks and was quite expensive, but it worked after that. Now I am having the "error code 2881" problem when I try to record with a DVD-RW. According to this website, our camcorder does not support that, it only uses DVR-R or DVR Ram. I am off to the store to buy some, and will let you know if it works.
Good luck Charlie.
Lynda
lyndelgado@hotmail.com
Jun 19, 2008 | Hitachi DZ-MV350A DVD Camcorder
Jan 03, 2008 | GoVideo Go Video DVD/VCR Combo
GoVideo Go Video DVD/VCR Combo Logo
117 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
