Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
Heater makes the three attempts with 30 sec. intervals. Ignites for 10 seconds on each attempt, but will not kick in and run after the initial ignition.
    Guru:
  • 642 Answers
Firstly make sure that the igniter is properly earthed. The ignitor itself detects the flame and if not properly earthed will not give the proper signal to the control unit. Next the burners need to be checked. They need to be properly cleaned of carbon deposits and oxidisation. If this does not cure the problem then do the following
Turn the gas output up to 2.5" wc(water column) Here's how :
To do this remove the slotted brass cap on the right of the gas valve. Adjust the output valve underneath one turn clockwise. Dont go more than this unless you're familiar with working with gas or have a manometer handy to measure output.
Posted on Aug 24, 2010
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
I lost all power in a 2005 Trailblazer. Called GM and they said to kick the key forward and wait 10 min, and this would reset it. It did but now the radio A/C door locks and windows don't work. What...
Do it three times in a row.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
Here is a link about the security problem
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 12, 2011 | Chevrolet TrailBlazer Cars & Trucks
Igniter goes on blower runs for 30 seconds main heater flame ignites and burns for approx 30 seconds then it shuts down for approx 10 seconds and repeats the same sequence 3 times, then shuts down...
there should be a flame detector sensor. it is in the flame. this will need to be cleaned with a wire brush or scrapped with something to get the carbon build up off of it.
you will see something that in in the flame area that is kind of charred and black with a wire coming out of it.
this is designed to tell the unit that there is a flame present and if that flame is not there after serveral attempts it will shut it down. because it there was no flame there you would get gas fumes pumped into you house.
you could change it out or usually you can just clean it and it will work fine.
hope this helps
rick
Jul 15, 2011 | Kitchen Ranges
The heater ignites but runs only for about 40 sec. and the reset kicks out
My guess is the reset is bad, esp if the heater runs fine for the 40 seconds. Next guess would be the thermostat, if equipped.
The problem could be as simple as a restricted fuel filter causing a starvation situation
Since the heater is on your bench and not mine you must troubleshoot to find the problem. This might help: http://www.reddyparts.com/SP_tips.htm
Oct 02, 2010 | Master Heaters B70DT Liquid Fuel Utility
Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
Shakes and cuts off
What motor, how many miles, and what maintenance has been done?
Mar 07, 2009 | 2003 Chrysler Concorde
Ford focus 1.9tdci LX 2002
hi
i have had the same problem (read article 26 jan 09 by terrytrout) i have now solved the problem. i got a fuel rail pressure censor from the scrapyard and for two days now the car has been running perfect. good luck.
terry
Oct 08, 2008 | 2002 Ford SVT Focus
Open Questions:
See all Hayward 100,000 BTU Pool Heater H100ID1 - Above Questions
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
111 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
