Question about Trust DS-4700R Keyboard and Mouse
Hello, I am an owner of a Trust DS-4700R mouse (I don't use the keyboard). All of a sudden my mousewheel and the back/forward-buttons stopped working. I can only use my mouse for clicking with the 'standard'-buttons and moving the cursor around. I have read that this may be caused by the batteries being empty, but changing them had no effect. Also installing the new driver was useless (first the mousewheel stopped working, then I 'updated' the driver and eventually the back/forward-buttons refused to work). This is kind of strange, since I have always used the mousewheel and the back/forward-buttons without a problem.
yooperbud
  • 8637 Answers
SOURCE: Trust keyboard and wireless mouse
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try typing to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
  • 108 Answers
SOURCE: wireless keyboard has stopped to work
Have you pressed the connect key on the usb receiver and keyboard. Sometimes you have to do this for it to be recognised after changing the batteries.
Posted on Jun 10, 2009
Zlobomir
  • 225 Answers
SOURCE: Mouse still working but keyboard is not working
try a wired working keyboard on the same port to identify whether it is keyboard or port fault.
Posted on Nov 08, 2009
firesnake09
  • 2923 Answers
SOURCE: my trust mouse is new and it isnt working it
- Try using fresh batteries.
- Make sure that the switch is turned ON.
- On the USB dongle and underneath the mouse, check if you will see a small connect button. If there is, hold down the connect button on both dongle and mouse at the same time for five (5) seconds and release them both.
- Try moving the mouse.
- Make sure that there are no possible wireless interference like base of a cordless phone or any other wireless devices such as cell phone. The wireless signal of these said devices might interfere with the wireless signal of your mouse.
Have a great day!
Posted on Nov 09, 2009
benwabnick
  • 2404 Answers
SOURCE: My Trust wireless keyboard and optical mouse will
Be sure that you have new batteries installed in the keyboard and the mouse.
After booting up into windows, plug them back in and see if windows detects them, if it does detect them it should install the drivers for the mouse and keyboard. If it doesn't then go here and download the drivers for it:
http://www.trust.com/products/productdrivers.aspx?artnr=14627
If after downloading and installing the drivers the mouse or/and keyboard still doesn't work, hit the connect button on the receiver for the keyboard and mouse. Then hit the connect button on the keybyoard and mouse.
This will make sure that both the keyboard and mouse synch with one another. If they still won't work after all these steps then you know for sure that either the keyboard and/or mouse are definitely bad and would need to be replaced.
Posted on Jan 11, 2010
Dropped wireless mouse and wheel shifted & buttons hard to push
I had a similar problem and was able to fix it. The left mousebutton was clickable, but needed extra force.
After opening the mouse I found that at the side of the mousewheel there was notch pointing upwards, preventing free movement of the left mousebutton. I was able to rotate the ring with the notch back into horizontal position after gently pushing the housing surrounding the mouse wheel wider.
Apr 25, 2010 | Logitech Cordless Mouse
My Trust wireless keyboard and optical mouse will not install when I start my computer
Jan 11, 2010 | Trust Wireless 11676 Keyboard
If I want to set another key to the mousewheel it detecs it like if i'm hitting the CTRL-button
My problem was:
When i was playing modern warfare 2 i couldn't change my mousewheel in a action button. Everytime i tried it said i pushed the CTRL-button?!?! Very strange and anoying!!!
How I solved my problem:
I googled vista and g5 as searchtopic. I don't remember on which forumsite i found the anwser. but it told me to go back to setpiont (settings for the g5 mouse) and change the direction of the wheel.
When i installed the mouse i directed the wheel to zoom. Now I set it on general button.
Now when i go to MW2 i can direct the wheel-button.
Hopefully i can help others with this.
sincerly Albert
Dec 18, 2009 | Logitech G5
Logitech Mouse V320 Corless Optical Mouse not working
The warrenty period is usually a year. Is there a connection button on the receiver as well? Normally you need to press the connect button on the mouse, and then on the receiver shortly there after. If you want to replace it, you might have an easier time just getting a new mouse.
Jan 25, 2009 | Logitech Cordless Mouse
Oct 23, 2008 | Trust Silverline Direct Access 12879...
Ds-3200 wireless optical slimline deskset mouse works keyboard doesnt
Normal 0 Make sure the batteries are installed and are good.
Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Aug 02, 2008 | Trust Wireless 11676 Keyboard
Labtec keyboard quit working suddenly
Here is the sequence to connect keyboard and mouse to receiver:
Press Connect button on receiver, and within 10 seconds press the Connect button under the mouse. Wait 15 seconds. Then press the Connect button on the receiver and within 10 seconds press the Connect button under the keyboard.
-- Thatpat
Feb 25, 2008 | Labtec 9675120403 Keyboard
Trust DS-4700R  Keyboard and Mouse Logo
75 people viewed this question
Top Trust Computers & Internet Experts
micky dee
Computer Links
Robin Hill
Robin Hill
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
