Question about Weller Welding Tools
Ungar 6970 heat gun. fan starts and slows to stop within 10 seconds.
    Master:
  • 577 Answers
Hello, replace the fan. GB...stewbison
Posted on Sep 07, 2011
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
WHY IS MY HINO 500 TRUCK OVER HEATING ALMOST TO THE RED ZONE AND THE COOLANT LEVEL IS ON THE MAXIMUM?
couple of reasons
have a compression test done to determine head gasket or cracked head
watch closely when the over heating starts and if it cools down
it the temp rises when going slow ( heavy traffic, hard pulling up hills , stop lights -- basically when the road speed is low and there is low/no air through the radiator-- check for a faulty fan clutch or viscous fan hub failure ( spins but doesn't pull air )
check for thermostat failure and not opening if from a cold start it is going to over heat within 5 miles of 10 minutes of idling
check for blocked radiator(internal)cores or radiator fins (external) falling off the cores
The first point of call for me would be the fan drive system
Mar 07, 2016 | Cars & Trucks
I had a custom built computer that was damaged in shipping: P55A-UD4, i7 860, ATI HD 5870, 8GB ram, Windows 64 bit, 120GB SSD running 3 monitors (2x20" 5:4, 24" 16:10). It would start-up but fail...
With everything you have i would look at power supply and see if you have enough power supply to operate video card motherboard etc.
Power supply could be overloaded and not able to operate video card correctly.
Which could cause issues with trying to run 2 or 3 monitors
May 18, 2011 | Gigabyte ATI RADEON 6970 HD 880MHz 2GB...
Hi, I have a Zanussi ZBF
Your fan is catching the element which has distorted with heat
Oct 04, 2017 | Zanussi Ovens
The Ungar we use at work was working just fine. Tried turning it on after only a short time of usage to shrink some shrink on a cable and she wouldn't fire up. Pulled her apart and can't see any really...
When testing a diode you need to lift one end of the component to prevent a second path of continuity. If you lift one end, and you have continuity in both directions when reversing the polarity, it would be shorted or defective. Does your Fluke have a Diode or Semiconductor setting? This will show you the voltage drop for the N/P junction which will be a better test than using the Ohm setting. If the diodes check good, test the motor windings, switch and heating element.
Mar 03, 2011 | Weller Ungar 1095 Dual Temperature Heat...
3 red lights fan works for a few seconds then stops.
If adjusting the screws on the heat sinks and using different size washers does not fix the problems you will need to reflow the motherboard. The absolute best reflow is performed using a rework station, although these are so expensive they are out of the realm of most hobbyists. I have a repair shop with a station if you want to be sure. I'll give you instructions on a possibly cheaper alternative, I fixed a bunch using this method when I first started way back in the early Xbox days.
You can also reflow using an oven or a heat gun. I've had better success with the heat gun.
The goal here is to heat the chips to about 260 C, the problem with the heat gun is it is a very imprecise method... Surprisingly though if done correctly it can work quite well. I must warn you though that if done incorrectly it could damage the MB beyond repair. I will give instructions below, let me know if you have any questions.
Essentially you will need to cover the outside of the board, including all the plastic capacitors with 5-10 layers of thick tin foil. You want to leave the CPU, GPU, RAM chips, and southbridge exposed for reflow. Put the foil on gently so as not to bend the capacitors, but firmly enough so it does not get blown off by the heat gun. Put the motherboard on a flat non-flammable surface.
Take your heat gun and start on low holding the heat gun about 4-5 inches away from the board. You cannot bump into or touch the motherboard during this process, you are basically liquefying the solder balls in between the SMDs. If you bump the board it will seriously mess it up so be careful.
You will want to move in a circular motion heating the board up evenly, do not stop moving the heatgun in the horizontal circular motion above the motherboard during this whole process. Do this for 2 minutes, then switch the heatgun to high and continue for 3 minutes, then switch back to low and go for 2 minutes. Keep the heatgun moving across the top of the board the whole time about 4-5 inches away. After you are done let the board sit for about an hour. Reassemble and test it out! Hopefully you will be greeted by the wonderful green lights! Haha.
Sorry this would be easier if I could post pictures.
Please let me know if you have any questions and good luck!
Mar 05, 2010 | Microsoft Xbox 360 Console
My xbox 360 stopped working with no video & audio. Replaced X-clamp. Now it starts (with no video & audio) and fan runs and after 10 seconds fan get louder and shows 2 red (left) light and fan...
i have only been able to fix one console that has had this problem and is what i did was took only the gpu heatsink off and covered everything but the gpu chip with aluminum foil, leaving only exposed the components that are not plastic, then heated the entire mother board with a heatgun that says it reaches 1100 degrees farenheight, focusing on no particular area for 2 min, heat gun on high with low air speed. after 2 mins. of heating mobo. top and bottom, focus heat on gpu and any where you do not have aluminum foil with heat gun about 14 to 16 inches away moving heat gun in circular motion ( you should use this motion throughout entire process, never keep heat gun in one spot, keep it moving) do this also for 2 mins. mainly focus on gpu though since most likely that is your problem.
Oct 15, 2009 | Microsoft Xbox 360 Console
On a 1997 nissan sentra will the radiator fan run all the time the car is running
No, it should only turn on when the temperature switch tells it to. On a hot day you may hear it running even after shutting off the engine. The fan is set up so that when you are moving at enough speed the fan shuts off to save energy, when you slow down or stop the fan should come on to maintain airflow. If you check it at this point yes it should be running. When you start it cold the fan will not turn on for maybe 10 or more seconds when the engine starts to warm up. Hope this helps.
Things to be concered about; 1.) the fan never seems to turn on. This will cause your engine to overheat when you stop.
2.) Your heat is not working. The heat going away can be a sign that you antifreeze is low and that you are about to overheat.
Aug 08, 2009 | 1997 Nissan Sentra
Boxlight CD-725C TEMP light comes on and unit shuts down afer 10 minutes. Unit has about 1200 hours on the bulb. Seconds before the unit stops, at least one of the fans slows down.
The reason why the temp comes on because the fan is start slow down, so the bulb produce a lot of heat. Once the maximum temp reach, the temperature sensor will become inactive. So boxlight shutdown. First you need to replace the fan, or check the supply dc voltage going to fan if it is stable.
Jul 24, 2009 | Office Equipment & Supplies
Welding Tools Logo
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
