Question about Whirlpool Dryers
Whirlpool dryer mod.yleq5000pwo runs but won't heat
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
2 Suggested Answers
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
I have a whirlpool gas dryer there is no heat and the dryer does not shut off
best advice is call a service man as GAS is dangerous to mess with
Apr 13, 2015 | Whirlpool Dryers
Whirlpool model yleq5000pwo
You don't, unless you use a cutting torch.
Apr 15, 2014 | Estate EED4400WQ Dryer
Dryer wont start
Part# 3392519 is most likely suspect as needing replacement. Located behind the main panel in the back of the dryer and mounted to the blower housing, long white/slightly oval. These thermostats can burn out for various reasons, it's best to have the home venting system checked by an accredited company to ensure it's properly functioning. Additionally Part# 3387134 should be replaced too.
Apr 11, 2014 | Whirlpool Dryers
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Hi, I have a Whirlpool dryer mod LHE780 that is running without heating up. Can you suggest a fix?
heatman101
Nov 15, 2010 | Whirlpool Dryers
Mod: LGR5620KQ1 dryer keeps running. timer stays the same.
sounds like short to ground and feed back to timer
Aug 31, 2009 | Whirlpool Dryers
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer not blowing hot air
Apr 11, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryers Logo
347 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
