Question about Whirlpool Heating & Cooling
I have Whirlpool model #ACQ128XP0, there is NO power at all to it, breaker is not blown, fan will work in the same outlet, so it is not the electrical outlet, i turned it on the other day, and it made the rising sound that it does right before it turns itself off in power save mode, then all the power went off on it, i have unplugged its been days
I am not an expert but I have two of the remote controlled 8000 BTU units and one of the 12000 BTU units like this one.
I have found that the remote controlled Whirlpool units that used this type of electronics sometime had a problem with cold solder joints on the motor control board. This is the board that has the relays that control the fan speed and compressor. Check for cold solder joints on all connections that have large diameter wire. These connections apparently did not get hot enough to properly flow the solder on the large diameter wire.
Posted on Sep 16, 2010
No power and no code error on my Whirlpool duet washer
possible you have blown the fuse inside the machine, or burnt out a component. if you have a multimeter you should test your fuse for continuity, then your pump and motor for shorts.
Nov 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
No indicator lights Whirlpool wdt710paym dishwasher
If it doesn't run and you have no indicator lights, check the circuit breaker for that outlet. If it is ok, test the output voltage at the plug-in for the machine (115Vac). If it is "live" then check inside the control panel (turn off the breaker first) for a fuse that appears blown. If no fuse problem, CAREFULLY (with breaker back on) see if the main switch is getting power. If it is getting power, the control board is shot...replace it!
Dec 28, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Amana PTAC model PTC123A50AC never had any problems until this a.m. walked into office were installed no heat. Breaker tripped, reset breaker, nothing. Checked outlet, getting power. Any idea's?
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
Jan 11, 2011 | Amana Heating & Cooling
Everything has gone of on my tumble dryer is there a reset button whirlpool 6th sense awz7814al
Try the thermal cutoff fuse... first check to make sure you have 220 power to outlet and not just a blown breaker. next check power at drier itself to make sure your cord is not bad.. if all is well, check door switch and make sure it clicks like it should.. Next, UNPLUG CORD FROM OUTLET!!!. pull back off drier, and locate thermal cutoff switch, located near bottom on the blower fan housing. locate the thermal cutoff fuse which is usually white in color approximately 2 inches long and narrow with two blue wires, remove and replace approximately $14.95 in Oklahoma. Replace and your back in business....
Dec 20, 2010 | Whirlpool Dryers
No electricity Clock is off nothing works
Plug something else into the outlet and see if the device works if it doesn't then reset the breakers. If the other device does work then the microwave is bad and needs replacement.
May 29, 2010 | Whirlpool MH7140XF Microwave Oven
My microwave just quit workin. It has absolutely no power.
Make sure breaker isnt tripped. If breaker isnt tripped just for the sake of knowing plug a fan or something you know that works in the outlet. If it works, you have probably blown fuses in the microwave you'll have to take microwave apart to get to them.
Aug 25, 2009 | Whirlpool MT4110SP 1100 Watts Microwave...
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
Whirlpool microwave 2003 stopped working & inside light is on
The most likely cause is a blown fuse or a kicked circuit breaker. Look in the cabinet above the microwave and see if the microwave is plugged into the ou let in that cabinet. If it is plug a blow dryer or some other little appliance in to that same outlet to see if you have power there. If no power go to your electrical panel and either replace the fuse or turn the breaker off and then back on.
Mar 18, 2009 | Microwave Ovens
Dryer will not start
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Heating & Cooling Logo
193 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
