Question about Xerox Phaser 8200 Laser Printer
I've suddenly got this error code
Would it be easy to cure?
Regards
  • GD91 May 03, 2008
    Regards
    President:
  • 2,072 Answers
That is a failure of the drum heater.
The easy way to determine if they are working is this.
Shut the machine off, turn the lights off in the office, or room the machine is in. Turn the machine back on. On the right side of the machine, there is a slotted area where the fan it, look in there and watch for a glow in the machine. Give it a minute or two, but if you don't see that glow, those heaters are not working.
They are not impossible to change, but requires some patience and care in replacing.
They are only, well if you live in North America, 120 volt, 150 watt halogen lamps. The simply burn out a filament.
You can go to Lowes or Home Depot and buy those. Or some local service Dealer could do that for you at a decent price.
If you want to try replacing those yourself, let me know, I will send you the procedure. Provide me your E-mail address and I will tell you how to replace those.
Please, do not pay the Xerox price for a new drum heater assembly, you will be stunned what they want for that item.
It really only requires replacing the bulbs, and most likely cleaning the contacts with some emery cloth.
Posted on May 04, 2008
ERROR CODE E 60 washing machine zanussi ZWG1100M
This can be due to error in the control board. Shut down and remove plug and when switched on press down the start/stop button. If the error does not clear this can be a fault in the motor drive within the control panel board.
Remove the panel and check the connections to the motor, check the motor and the capacitor to the motor or if the motor is jammed.
Jul 03, 2012 | Zanussi Washing Machines
I get error code Disc error 972. Is there an easy fix for this Regards Steve
From what I can tell, this error is caused when you've burned your own disc on a DVD+R/+RW. The Wii console only supports DVD-R/-RW. Check your media to see if you have DVD+R, and, if so, try burning onto a DVD-R (or DVD-RW, in case it doesn't work) and check it in your Wii again.
Jun 21, 2011 | Nintendo Wii Console
I've had kodak easy share on my computer for years. Recently I tried to access the pictures and got "can not process your request..(error code 9477068x301x94770168x) I have called them &...
Forget easy share, just take out the memory card (SD card) from your camera and buy a SD card reader. Put this memory card in the card reader and plug the card reader in your computer USB. It will work like a normal pen drive and you will find all your pictures inside DCIM folder of your memory card. Copy all pictures in your computer HDD to be on safe side.
May 07, 2011 | Computers & Internet
How do you fix an error 57E- when trying to update office 2003
This is a repeated error code which despite Vista SP1 being installed has not
cured my problem. However I can offer this slight bit of salvation which has
done me well over the past 12 months. Should any updates fail to down load
and all your favourite error codes suddenly manifest themselves - do the
following. Go into microsoft support and type in the download, ie KB12345, it
may take a while to find the right branch of Microsoft, but in every occasion
I have found what I have been looking for. I hope this helps.
Nov 08, 2009 | Microsoft Office Standard Edition 2003
Error code 80010514
you need to call Sony and tell them about the error..its like the RROD of Xbox360..a hardware failure,most likely with the lens mechanism..i had the same error too and had to pay up to get it repaired..hope your console is under warranty..all the best!regards!
Nov 28, 2008 | Sony Playstation 3 (PS3) Console
SONY uvw 1800 Error Code 02-454
The unit powers on, the drum shows only 0005 hours on it, but the display says it has an "Error 02-454" Error Code, and says "REC Inhibit", and it will not accept a tape. When this unit is powered on it shows error code 02-454 which is:
S-REEL FG COULD NOT BE DETECTED WHILE IN FF/REW MODE.
You can cross-reference this error code at the following web site:
http://www.johnjvsvisual.pwp.blueyonder.co.uk/UVW1600-1800%20error%20codes.pdf
From what I’ve been told this is a very easy fix for someone that knows how to work on these. It is a very clean machine, inside and out, and I am sure it is well worth getting serviced and put back in use
Aug 02, 2008 | Acer TravelMate 3260-4542 Notebook
Error code cc3-205-03031f02 will not scan
What model do you run? Is it a brother mfc 240c or something diffrent?!!
I ve never seen such an error code for brother mfc 240c printers!
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
Xerox Phaser 8200 Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
