Question about Toshiba Satellite A135-S4527 Notebook
My p10 suddenly lost power there is no green mains light showing but have tested the mains adapter and voltage is correct.is their some form of overhear device which cuts out. Jim
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Aug 21, 2010
Roland r8 has flashing green light
Are you using the correct AC adapter? An aftermarket unit will do this if the power is insufficient, or the polarity is wrong (- / +). If you're using an aftermarket unit, it may not be providing the right amount of Amps and Voltage to the unit; causing the display to blink. You can try this cord to help: http://www.powerpayless.com/ac-power-adapter-for-roland-r-8-r8-drum-machine.html
Jan 13, 2013 | Music
Suddenly won't turn on no charge light indicator
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 25, 2012 | ASUS G71G-A2 PC Notebook
Power light go's on and off
Remove main battery and try again, next! sub out one ram stick at a time testing as you go, if still no result! check power adapter for correct voltage, if okay! the motherboard needs to be assessed.
Mar 20, 2012 | Gateway NV7802U Notebook
Lexmark x4650 hi, I have plugged a in the printer, nothing happening at all , no indicator lights, it has suddenly died , last used it a couple of weeks ago , any suggestions ? thanks
Verify that the power cable is firmly connected into the printer. Plug the printer in to a different outlet, one that you have confirmed works (plug in a lamp to verify that the outlet works). You may plug in the printer without the computer connection to test this. Check to see if the printer has an additional power switch on the back near where the cable attaches. If the problem persists, verify that the voltage is correct with a multimeter. The output voltage should correspond to the DC Output value written on the adapter. Confirm that this voltage matches the DC voltage required by the printer as written on the underside model placard on the printer. If the voltage is incorrect and the adapter is the correct one for the printer, replace the power adapter. If the voltage is correct then there is a problem with the printer that requires repair service. You may want to consider a new printer if this one is not covered by your warranty.
Apr 02, 2011 | Office Equipment & Supplies
My computer won't turn on at all, the green light comes on but only a black screen shows. When it was plugged in to power the light wasn't showing that it was charging so took out the battery and then...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
I tried to switch on my laptop and it started booting and suddenly went off.From then on its not even booting.Nor does it show the green light which comes on, when you plug it to a power source. Its...
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
A faulty adapter or the connector is not making proper electrical contact, this causes the LED not to illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
May 09, 2009 | Lenovo R61 T7300 Notebook
E Book 500GB drive does not get power
It sounds like the adapter more than the e-book.
If the adapter plugs into the e-book, remove it and buy another one with the same voltage and correct power orientation. The best way to do this is to take the old adapter with you to any shop that sells electrical equipment - even K-mart has them.
If it's one of the fixed adapters, it's best just to take it to a sparky and have them change the adapter for you, it's a 2 minute job.
Feb 09, 2009 | Western Digital My Book Essential Edition...
Toshiba m35-s456 no power
To test if the adapter is faulty check it with a multimeter.
Test the output voltage on the connector that plugs into the laptop. The voltage should be 19 volts (the voltage is printed on the label on the adapter) or slightly higher because the is no electrical load on the adapter.
If there is no voltage or if the voltage fluctuates when you flex the power connector, then the adapter is faulty.
If the adapter is OK, then plug it into the laptop and the jiggle the connector a observe the charging LED light and if it flickers the fault is the power connector on the laptop. This can be repaired, it needs to be resoldered or replaced.
Jan 24, 2009 | Toshiba Satellite M35-S456 Notebook
R40 2724-BU1 Power Problem
Check the ac adapter. It seems your adapter is not charging it. Either the ac adapter or your dc port may be the problem. Is this the correct adapter, is it giving the correct voltage. These should be considered also.
Hope this helps you
Oct 20, 2007 | IBM ThinkPad R40 2722 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
