Question about Kenmore Elite 45986 Front Load Washer
Washer will not spin... belt ok Kenmore Elite HE3 45862
  • Kenmore Master
  • 17,130 Answers
Use a multimeter to check if the motor is OK. If there is an open winding or if there is a leak to the body then the motor is faulty.If not check the capacitor and replace. Now test with the program. see if voltage comes in after the wash cycle starts. If not the controller is faulty and needs a replacement.
Since you mentioned only the spin part I assume the controller is OK and the rest of function like water loading etc., is working.
Hope you work on the advice.
Posted on Aug 21, 2010
I have a kenmore elite he3t washer and when it gets to the spin cycle it doesn't spin what could be the problem?
could be a bad door switch, bad motor coupler or clutch or even a busted belt depending on ur machine being direct or belt drive?
Feb 17, 2015 | Kenmore Washing Machines
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have an kenmore elite =sm9711174. the spin cycle does not always start. i have to manually spin a couple times then it starts, but now does not spin fast. only slow. do i need a new belt?
this washer does not have a belt. The motor is a direct drive. it should give you a error code at time if it is unable to spin. some codes are F-51, F-dl, and UL. from the sounds of it the main board may need to be replaced part#W10189966.
Sep 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer weak agitate even at fast load and no spin
It could need a new belt. If there is damage on the belt it may also be dirty or stretched and thereby slipping and not giving you it's best performance.
Aug 01, 2017 | Kenmore 43142 Front Load Washer
Slow Spin Rate
ok " sounds like belts are slipping, readjust or replace belts
adjustment bolts on motor will tighten belts
Jan 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
236 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
