Question about Canon PIXMA iP5000 InkJet Photo Printer
I put in fresh black ink jet cartridges in and I am positive they are in correctly yet it will not pick up black print numbers ect.
  • Canon Master
  • 17,130 Answers
When the ink cartridges were installed there is a possiblity that you have not used the procedure to replace the ink.
hence there is a chance that the software is having a conflict.
Disconnect the printer and uninstall and then reinstall the software of the printer. Then reconnect the printer to the PC .The hardware will be detected and installed. Now make a head cleaning and do the test print.
If this wont help, it is possible that the printer's head is faulty.
Hope my advice helps.
Posted on Aug 21, 2010
Ink jet cartridge
  • 1 Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
  • 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
  • 3 Wait a moment. The cartridge carrier will automatically disengage.
  • 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
  • 5 Carefully pull the tape off the new cartridge.
  • 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
  • 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
  • 8 Close the printer's lid. Print a test page to ensure everything is working properly.
  • Hope It's resolve all Your Printer Problem,
    Or Still having Problem Then follow Us For
    Canon Printer Support
  • Apr 22, 2014 | Canon MX340 AllInOne InkJet Printer
    WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
    This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
    NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
    To resolve this issue you will need to clean the print head.
    NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
    1. First verify the position of the ink cartridges:
    a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
    b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
    - If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
    - If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
    Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
    When all the cartridges are installed, close the ink cartridge cover.
    2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
    1. Press the INK key.
    2. Press OK to select Test Print.
    3. Press OK to select Print Quality.
    4. Press the COLOR START key.
    5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
    a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
    b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
    6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
    a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
    b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
    c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
    d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
    NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
    e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
    If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
    NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
    7. Test by printing the document that had the reported problem (wrong color printing).
    Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
    Black not printing
    Canon Bubble Jet i560 Ink Jet Printer not printing black
    Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
    Office jet 5510 keeps saying wrong black cartridge.
    Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
    Jan 30, 2010 | Office Equipment & Supplies
    Check color ink always blinks and does not allow to do any job.
    Make sure that you installed the correct ink. It is not enough for it to fit, the numbers on the cartridge have to match those on the cartridges you replaced. You may also have problems with off brand ink that claims to work. Use Kodak ink. Also, many of the Kodak have the ink jet nozzle on the printer, not the cartridge.You can try cleaning in and around the cartridge casing, especially on the copper areas, with an alcohol swab. Then run the cleaning utility on the printer 2 or 3 times.
    Nov 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
    Put in new ink and it is telling me out of ink and will not let me print anythings.. How do you reset ink
    Simple oly when you know how ;-)
    I think you have a slight blockage, to solve:- (dont know which printer or PCyou have so ill do my best)
    Click on Start
    All programms
    Pick your printer from the list
    Open the software
    You will have 2,3 or 4 options depending on your printer spec.
    You need to 1st remove the cartridge
    Print 1 page with no INK a message will pop up saying con not print need ink for example.
    You then NEED to calibrate your cartridge, you need to find:-
    1 Align Cartridge/Nozzle - Unblocks, and Sets up. (Syncronize)
    2 Calibrate Black - unblock black
    2 Calibrate Colour - unblock colours
    3 Print test Page - See how it looks
    5 Align again - Unblocks everything giving good ink flow and gets the print right close to 100%
    6 print test page!
    It shoud now work ;-)
    Good Luck xxx
    Jul 15, 2009 | Canon Pixma MP480 All-In-One InkJet...
    HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
    it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
    byee
    May 09, 2009 | Office Equipment & Supplies
    Print cartridges
    1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
    2. Lift the top cover to the open position until it locks securely into place.
    3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
    4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
    5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
    6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
    Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
    Mp140 e2
    E3 – Paper jam error.
    How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
    1. Confirm there is no foreign material inside the machine.
    2. Confirm only recommended paper is installed.
    3. Confirm paper is installed properly.
    4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
    E4 – Empty ink tank.
    How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
    E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
    How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
    E7 – The ink cartridge is not installed in the appropriate position.
    How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
    E8 – The ink wasteabsorber is almost full.
    How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
    E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
    How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
    1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
    2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
    3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
    E14 – Ink cartridge cannot be recognized.
    How to correct, fix: Unsupported ink cartridge may be installed.
    E15 – Install only recommended ink cartridges.
    How to correct, fix: Install only recommended ink cartridges.
    E16 – The ink level cannot be correctly recognized or detected.
    How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
    E19 – Scanning failed error.
    How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
    Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
    Epson Stylus Printer CX4600
    I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
    Hope this helps
    Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
    Canon PIXMA iP5000 InkJet Photo Printer Logo
    51 people viewed this question
    old marine
    old marine
