Question about SCARABEO 50/R White Kong Set Sink
Sudden loss of almost all power, mostly when climbing hill.
What causes Soltice to rev up and down shift when climbing hill but loose speed
That is the way gears in cars work. When you go up hill, the car needs more gas, so you put your foot down, kick down comes into play and the gearbox chooses one gear lower, for more engine revs and lower speed you get more torque to climb the hill.
Get the car tuned up, you might have failing sensors or ignition problems causing a general loss of power that is needing kick down on hills.
Dec 25, 2016 | Cars & Trucks
Loss of power climbing hills. Replaced the loss of power climbing hills. Replaced the transmission 2 years ago. Could it just be a dirty fuel filter or a bigger problem?
I got this, and it was a failed trans shift solenoid no 1. This rendered the trans unable to find low gears. However there should be a trouble code notified by a light on the dash.
Jun 17, 2015 | Cars & Trucks
Loss of power when going up
in the first place you must change the filter and the transmission oil in your automatic gear box , if the problem persists and your gear box shift not the gear for climbing hills it is a tehnycal problem with your gear box , but in my opinion ( i had a similar problem with my car ) this is the only problem. God help You ! Sorry for my English !
Apr 27, 2012 | Cars & Trucks
Loss of power and hard starting
Check fuel pressure with gauge attached and taped to windshield. Go for a drive. Check for codes and check out TPS Sensor. Odds are high for the spider,issues.
Mar 12, 2010 | 1997 Chevrolet K1500
check catalitic converter,could be partially plugged
Aug 02, 2009 | 1999 Dodge Ram
Engine raced with sudden loss of power climbing hill
Sounds like the transmission went south on you..(surge and power loss was the trans not sending power to the wheels, allowing the engine to freewheel as the cruise applied more power to try and maintain speed).Depending upon how high the rpm's went when it let go, it may have damaged the engine, but that remains to be determined...Your mechanic will likely concentrate on that before putting a transmission on a wounded engine. The one grain of hope in what you said is that it remained running while you had the a/c on waiting for a tow. Good Luck!!
Jul 10, 2009 | 1998 Toyota Camry
SCARABEO 50/R White Kong Set Sink Logo
48 people viewed this question
Top SCARABEO Home Experts
john h
Tom Chichester
Are you a SCARABEO Home Expert? Answer questions, earn points and help others
