Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I am trying to program my wireless garage door keypad and it does not cause the opener to blink or click. Is the keypad dead?
    President:
  • 3,197 Answers
If you are sure the battery is good and you are programming it properly then your keypad must be bad.
Posted on Aug 23, 2010
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Mar 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster security+ - enter code on keypad and background light blinks and door won't open. How do I get door to open?
Try programming it by pressing and immediately releasing the smart/learn button and then walking over to the keypad and keying in your four digit code and press enter. If this doesn't work your keypad is bad.
Jan 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Garage Door opener model 3850. Sometimes the keypad will not open door. Instead the lights behind all the numbers blink in unison. What is it trying to tell me? Thanks Jim
The blinking lights are normal when you enter a code and press enter. I would try programming it and if that doesn't work replacing it. To program it you press and immediately release the smart/learn button on the rear of the motor unit and then key in your 4 digit code and press enter.
Dec 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open. no lights flashing on
Check to make sure that the lasers at the bottom of the door on each side are lined up. Sometimes it is easy to bump them and then they will not see each other causing the garage door to not work. Worth a try.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless Keypad wont allow use of other door openers
hit learn button for 10 seconds. now nothing will work except wired buttons. Hit learn for 1 second and put in yur 4 digit keypad code and hit enter, light on motor will blink twice. hit learn again for 1 second and push button on remote. again bulb will blink. continue pushing learn for 1 second and adding another remote.
Dec 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Model 13553965- programming wireless keypad
You have to buy a liftmaster or craftsman keypad
May 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
70 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
